Springer fork?
Discussion in 'XJ Modifications' started by Proar, Apr 30, 2016.
  1. Proar
    Proar Member
    Denmark
    Hello guys. New owner of a xj 750 seca from 82 today. This is my second build and im planning on doing a bobber this time.
    I would really like a springer fork and i was wondering if its possible with a universal one fro. Ebay or something
    Or maybe some of you know of one?
    Im from europe so this whole inches thing is confusing me a bit
    Ill take any advice and tips that comes up
    Cheers!
  2. Eurotas
    Eurotas Member
    Edmonton
    I went to a bike shop today to see if I could get one fitted to my bike and it works! We're not sure about clearance for bearings yet, but I'll be bringing just the frame back to see if we can make it work. There might be a possibility of some light machining if things don't quite fit.
  3. Proar
    Proar Member
    Denmark
    Any idea what the dimensions were? Especially the width down by the wheel as i need the disc brakes to fit
  4. Eurotas
    Eurotas Member
    Edmonton
    It's pretty much a Harley conversion on the whole front end.
  5. Proar
    Proar Member
    Denmark
    Well i live in a country where we are more limited on changes...not even sure if i can get springer forks on it legally
  6. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    Du får registrera den i Sverige så blir det inga problem, synd att förstöra en trevlig cykel dock...
  7. hogfiddles
    Yeah.
  8. Proar
    Proar Member
    Denmark
    kan det lade sig gøre? at have bostand i danmark og så en motorcykel på svenske plader?
  9. hogfiddles
    Sprechen sie auf English, bitte?
    Danke,
    Herr Dave Fox
  10. Big swede
    Gothenburg,Sweden
    Tror det, kan vara värt att kolla. Vet att det är lättare att få igenom ombyggda fordon här åtminstone.
  11. Big swede
    Gothenburg,Sweden
    Sorry MR Fox, it was easier to write in swedish.... Won't do it again:oops: Just told him he could register hos bike in Sweden instead as our regulations with modified bikes/cars are not as hard as in Danmark.
  12. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    No delete post option!
  13. XJ550H
    if you know the width of the forks at triple tree you can figure the width at the wheel
  14. hogfiddles
    Lol
  15. Eurotas
    Eurotas Member
    Edmonton
    Here's my Springer that I'm putting on.
  16. Eurotas
    Eurotas Member
    Edmonton
    But here's the problem with the bearings....
  17. Proar
    Proar Member
    Denmark
    well i found a way to get the approval here where i am but its a costly risk. around 1200 dollars for a test at a motor office wich i might fail. so i might end up back at the drawing board...shame though
  18. Big swede
    Gothenburg,Sweden
    That wasn't cheap...:-( Can't you just ask them in advance if they will let it pass?
  19. Proar
    Proar Member
    Denmark
    Nah man. First its a written inspection and then its a physical test with the fork im planning on buying. So all in all i risk around 2k for it :/
  20. Eurotas
    Eurotas Member
    Edmonton
    What if you buy one already done?
  21. Big swede
    Gothenburg,Sweden
    Sounds like it's not worth it...:(
