ss brake lines installation help
Discussion in 'XJ Technical Chat' started by atopetu17, Dec 10, 2008.
  1. atopetu17
    atopetu17 New Member
    Costa Rica Central America
    i got ss brake lines and fittings, should i just thead the fittings down or is it better to use thread lock to be safe?, thanks for the help
  2. wamaxim
    wamaxim Active Member
    Vancouver, USA
    I've been wondering. Are you using ss tubing or ss mesh over rubber for your brake line
  3. atopetu17
    ss mesh, they are from biker s choice
  4. schmuckaholic
    California
    I just snugged them down with a torque wrench. See the referenced file for the specs.
  5. atopetu17
    what i have to do is atach the hoses to the fittings first, and then to the master cylinder, the hose-fitting joint is what concerns me as to use or not thread lock compound
