SS brakes lines.
Discussion in 'Hangout Lounge' started by biggs500, May 31, 2012.
  1. biggs500
    biggs500 Active Member
    Sherwood WI
    Ok, finally got my blue sheathed SS brake line installed. Huge difference and the color works, or at least I think so. :)
    Here they are:
    Bye bye rubber devils!
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    decent match to the blue in the decal. looks good
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Nice color splash!
  4. Furman
    Furman Member
    Windham, ME
    Good choice! Works great with the decal color. Full bike pics?
  5. mtnbikecrazy55
  6. bigfitz52
    Along with the full-floating rotors, once the brakes get bedded in, you're going to notice a really nice improvement in performance. If you haven't done it already, replace your fork springs with a brand new set of Progressives and the thing will stop better than you would have ever believed.
    You need a new speedo cable rubber ring mounty-thing for the fender there. Len should have them.
  7. mwhite74
    mwhite74 Member
    Looks sharp Biggs!
  8. biggs500
    Sherwood WI
    I noticed the (substantial) performance increase immediately. I had about two hundred miles on the rotors and pads when I put these on. I was very happy with how fast I was able to bleed the lines too, last year when I rebuilt the calipers I worked on the bleeding for what seemed like a couple of hours. These took maybe twenty minutes. :) It's nice pulling back the brake pedal (sorry, I just had to) :p and having it just plain stop about half way in.
    And that speedometer cable holder thingy, that broke probably back in the early '90's and it's something I keep forgetting about. I actually finally just cut the loop off the cable a few weeks ago, it was just hanging there for about 20 years. :oops: I should put one on my list. :)
    I also have a pair of D rings on my helmet lock as a reminder not to use it. Back in the mid eighties someone wanted my Bell Star more than I did. :x Not sure what good it was without a means to fasten it though? Live and learn I guess.
  9. dboogie2288
    dboogie2288 New Member
    Looks real nice, I've got the same bike, what lengths did you buy of lines? I'd love to order them without having to first disassemble the system if at all possible.
  10. biggs500
    Sherwood WI
    I ordered them from XJ4ever. The link is at the top right of every page. The prices are a bit higher now.
    HCP2843BLUST Aftermarket DOT-approved braided stainless steel BRAKE LINE ASSEMBLY, from the master cylinder to the distribution joint, with bright blue sheathing.
    $ 44.95
    HCP2844BLUST Aftermarket DOT-approved braided stainless steel BRAKE LINE ASSEMBLY, from the distribution joint to the left brake caliper, with bright blue sheathing.
    $ 49.95
    HCP2845BLUST Aftermarket DOT-approved braided stainless steel BRAKE LINE ASSEMBLY, from the distribution joint to the right brake caliper, with bright blue sheathing.
    $ 49.95
