Started Button
Discussion in 'XJ Technical Chat' started by mccasks1, Jun 5, 2013.
  1. mccasks1
    mccasks1 New Member
    Grand Rapids
    I'm having issues getting my bike to turn over. I ran thought this check list ( http://xj650.blogspot.com/2009/03/how-t ... rcuit.html ) and it seems to be my started button. After cleaning and inspecting I cant find anything wrong with the button but it still doesn't check out. Would I be able to replace it with this ( http://www.amazon.com/Momentary-Button- ... tton+xj650 ). If so, what wires would i connect to the button (Blue/white and red/white). Thanks for all your help guys i really do appreciate it!
    McCaskey,
  2. wizard
    Do you intend mounting that in a new location ?
    The wire the the start button just goes to ground to make a circuit.
  3. mccasks1
    mccasks1 New Member
    Grand Rapids
    Didnt know that so if i hook the blue/white wire to it then make a ground wire i should be fine? will i still need my cut off switch or is there a way to by pass that so it is always on?
    Thanks,
  4. mccasks1
    mccasks1 New Member
    Grand Rapids
    i have an 81 XJ650 by the way
