Started on the carbs....
Discussion in 'XJ Technical Chat' started by ned6x4, Jun 13, 2012.
  1. ned6x4
    ned6x4 New Member
    Warren, Michigan
    I have a couple quick questions (the first of many). While removing the float bowls, a few of the float bowl screws had to be severely maimed in order to get them out. Are these screw's unique or can I pick them up at the local hardware store? After I got the float bowls out, I went to remove the float pins. Are the pins supposed to slide out easily? How much force should be applied to remove them?
    This is my first crack at carbs so I figured I'd ask before I started ripping stuff apart and putting random screws into float bowls!
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    the float pins in my 85 xj700N slide out very easily. Be very careful or you can brake the float post and the carb will become junk.
  3. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    The screws are all JIS.... If you're not using JIS screwdrivers, you're gonna maim them. you can replace the screws with US Metric equivalents no problem (replace all of them!)
  4. scubaroboto
    scubaroboto Member
    Connorsville WI
    I used hex screws so I could use an allen wrench. Much easier to take apart again later and less likely to strip them out again.
  5. ned6x4
    ned6x4 New Member
    Warren, Michigan
    Thanks guys, I was aware that they are JIS. I will definitely swap them out with something else. I was leaning towards hex screws and Scuba finished selling me on that idea. Now I will tread lightly through the rest of this carb process. Wish me luck...
  6. ned6x4
    ned6x4 New Member
    Warren, Michigan
    Here comes the next hiccup! The pilot jet in carb #2 is severely marred, black, stripped, ugly etc. How on God's green earth do I go about getting that bugger out? Thanks in advance!
  7. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    Well, I had the same problem with my pilot jet and was able to get a small pair of vise grip pliers locked on it and turned. It made it much easier. Unfortunately now I need a new jet.
  8. ned6x4
    ned6x4 New Member
    Warren, Michigan
    FINISHED!! That was very tedious and time consuming. It won't be nearly as difficult next time. Regardless, it's done and I didn't break anything!
  9. fintip
    fintip Member
    Austin
    on the mikuni carbs, those float pins can be really difficult, and you have to be VERY careful not to brake a float pillar arm.
  10. ned6x4
    ned6x4 New Member
    Warren, Michigan
    Yea, I was worried sick the whole time...even putting the pins back in! I used the technique/trick outlined in this tutorial:
    http://www.mtsac.edu/~cliff/storage/gs/ ... torial.pdf
    Nail setting punch to tap the pin out and a socket to support the pillar...worked like a charm
  11. CBnutt
    CBnutt Member
    Archbold,Ohio
    that tutorial helped me tons
