Starter button ground, the handlebars? (new questions)
Discussion in 'XJ Technical Chat' started by broberg, Jun 24, 2013.
  1. broberg
    broberg Member
    Sweden, Östergötland
    Yes, does the start button circuit go through the handlebar?
    The ground that is, Cause the cutoff switch and the light switch all work as they should, but the button does nothing.
    Thank you.
  2. bigfitz52
    Re: Starter button ground, the handlebars?
    Yep. If you install black-painted or powder-coated bars, then you'll need to "make a clean spot" for it.
  3. broberg
    broberg Member
    Then thats what I'll do!
    Thank you fitz
  4. broberg
    broberg Member
    Okey, got the ground sorted, also found a broken wire to the starter relay,
    re-soldered it and but it back in, great, now I hear a faint clicking sound but the starter does not engage.
    I jumped the leads to see if the starter still worked, and it did.
    So I'm guessing the relay is broken?
    BUT!
    Secondly, my neutral light have become inversed, so When in neutral the light shuts off and when in gear it lights up, any thoughts on that issue?
    (it turns off when I pull the clutch lever)
