Starter clutch, need help on how to install.
Discussion in 'Hangout Lounge' started by pops4u, Dec 31, 2011.
  1. pops4u
    pops4u New Member
    Montgomery, Alabama
    I need help on how to install starter clutch in a 1982 xj750 maxim. All help is most welcome! Thanks!
  2. bigfitz52
    The starter clutch is BURIED in the motor, and will require splitting the cases.
    YOU NEED A MANUAL for this.
    Why do you think you need to replace the starter clutch?
  3. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    If you are running synthetic oil in your 750, dump it, do 2 oil chamges with conventional oil then see if the problems go away.
