Starter issues... I think.
Discussion in 'XJ Technical Chat' started by Axle, Jan 14, 2009.
  1. Axle
    Axle New Member
    Groton, Ct.
    Try to turn it over, even with a 50 amp jumper attached, but it struggles to turn the engine. After a turn or two, something just clicks fairly rapidly. Only way to get it started is to roll start it, but the roads are too icy. Any ideas?
    82 xj750j
  2. TheHound
    TheHound Active Member
    Scotia, NY
    If it will bump start the engines not siezed.
    Something is binding in the starter.
    If you remove the starter does it spin free, does it spin with voltage applied?
  3. switch263
    switch263 Member
    Austin, TX
    On cars start clicky is usually a bad solenoid. Definately test it off the bike though too.
  4. Lou627
    Lou627 Member
    Queens, NY
    yeah try taking the starter out and seeing how it spins grounding it and attaching the lead to the/a battery.
  5. turtlemann14
    turtlemann14 Member
    low battery, mine does the same thing when the battery is dead
    the clicking it the solenoid clicking off and on
  6. switch263
    switch263 Member
    Austin, TX
    this too
  7. Alive
    Alive Active Member
    Queensland, Australia
    Quick solenoid test.... put somehting metal across the 2 bolts on the solenoid... If it starts normally it's a new solenoid... If not then I'd be moving on to the starter motor
  8. Axle
    Axle New Member
    Groton, Ct.
    Thanks everyone. I'll take these ideas and try them out.
