starter misfire (not engaging starter clutch i assume)
Discussion in 'XJ Technical Chat' started by bossnoss77, Aug 31, 2008.
  1. bossnoss77
    bossnoss77 Member
    orem utah
    Hello intermittent starting issue. Most times it will start, but every once in a while it just spins. Minor problem to repair or major? I pulled the starter an it is just fine. I assume the bendix/clutch is in the case?
    time to split the motor?
  2. bill
    bill Active Member
    Raleigh, NC
    Maybe. Several things to check first since that would be a big job. Make sure your battery fluid is full and it's fully charged. Make sure your starter relay is in good shape. Idea is any thing that can cause a voltage drop can cause the starter not to spin quickly enough.
    I had this issue when I switched to synthetic oil. Going back to dino solved it. I also see it from time to time when the battery is weak from cranking during tuning.
  3. bossnoss77
    bossnoss77 Member
    orem utah
    thanks ill check it out
