Starter motor won't stop spinning
Discussion in 'XJ Technical Chat' started by tjb2of3, Apr 18, 2011.
  1. tjb2of3
    tjb2of3 Member
    Charlotte, NC
    I just got my new starter motor in the mail, and when I put it on my bike, an interesting thing happened: when I pushed the starter button, the starter turned over, but then didn't stop when i took my finger off the button. also, the kill switch didn't do anything (in either direction), and even with the keys out of the ignition, it kept spinning. The only thing that stopped it was when the battery eventually died. Anyone have any ideas where/how to start testing?
  2. firebox40dash5
    firebox40dash5 Member
    Stuck starter solenoid. Under the seat (or maybe the right side cover, I don't know the 550 that well) with 2 big wires and 1 or 2 smaller wires running to it.
  3. JFStewart
    JFStewart Member
    Ontario Canada
    Sounds like the solenoid stuck. Try tapping it to see if it frees up. If the battery was low, the amps through the motor would have been high and may have "welded" it. Should that happen again, disconnect the battery rather than letting it "die". TO follow up , the solenoid is located under the right cover. It is easier to reach with the seat off.
  4. bigfitz52
    Sounds like somebody needs a new solenoid.
  5. mwhite74
    mwhite74 Member
    you might want to make sure that you have the Positive on the battery connected to the right post as well, not sure how much fiddling around you did with it previously... or you need a new solenoid :p
  6. tjb2of3
    tjb2of3 Member
    Charlotte, NC
    Yup, you guys nailed it. Charged the battery back up, swapped out the solenoid, and sure enough, it started with no drama whatsoever. Thanks for the help!
