steel brake line
Discussion in 'XJ Technical Chat' started by oak450, Feb 2, 2008.
  1. oak450
    oak450 Member
    The foothills of Oregon
    I'm pondering replacing my 25 yr old factory brake line with stainless steel. Any recommendations for brand of brake line to use, or other general advice on the matter?
  2. blackdiscoball
    blackdiscoball Member
    dayton, Ohio
    I'd like to hear some ideas as well.
  3. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I replaced mine with Russel's universal hose. It's a SS hose with a clear protective wrap. With that and a couple banjo adapters, it works very well. Not only that, since my 81 only has one front unit, I did away with the two short hoses and ran just one long hose. This actually saved me a lot of money.
  4. Altus
    Altus Active Member
    London, Ontario
    I did the same as Wink - replaced with one long line and got rid of the useless 90° bend in the middle.
    One note that I'm not sure people understand -- "stainless steel line" is actually a teflon tube covered with steel braid for strength, then usually a clear coat for protection.
    Anyway - I just ordered a 40" line, 1 straight banjo (master cylinder end), 1 30° bend banjo (caliper end) from my local dealer - was less than $50 and was money VERY well spent.
  5. yamyboy
    yamyboy Member
    Toronto Ont Canada
    Braided lines dont expand like the rubber hose that came factory so you have stronger braking power. Iv used Russel lines on both my frount bracks and oil cooler with no problems.
  6. RickCoMatic
    Everyone I have ever talked with that changed-over to Stainless Brake Line has said that they got much better Braking Power out of their systems because of it.
    It also makes for a very nice looking cosmetic mod; too!
  7. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    It doesn't really matter what kind you get. Any that you can find that fits is better than the old rubber hose. I got some on ebay for a Harley that were $12 each and they work great.
  8. danno
    danno Member
    Union Springs,New York
    I replaced the line on my '82 650 Maxim with a Galfer ss line from cyclebrakes.com. Awesome fit and finish,choice of colors,and no clunky adapters as found on universal lines. Great folks to deal with,as well.
  9. oak450
    oak450 Member
    Cool. Time to go shopping.
  10. oak450
    oak450 Member
    Altus, wink, I'm trying to figure out the right adapter for a russel brake line. The banjo bolts - are they 10mm or 12mm? I used a 12mm wrench to take off the union bolt, not sure if that means the banjo is 12mm.
  11. Altus
    Altus Active Member
    London, Ontario
    Nope - wrench size has nothing to do with it - you want the 10mm ones.
  12. wink1018
    Muncy, Pennsylvania
    Correct. 10mm banjo's. You won't need the bolts, if you have the originals.
    I highly recommend getting two 30* adapters. And you can tell from the one picture that the hose is an Earl's unit. I purchased all my parts from Jegs.
