Stock exhaust, can it be made more aggressive?
Discussion in 'XJ Modifications' started by invader_gir05, Aug 20, 2008.
  1. invader_gir05
    invader_gir05 Member
    I like the look of the stock exhause on my 82 seca 650 otherwise id have ditched it already.
    What im wondering is if there is a way to make it slightly more free flowing and slightly louder without completely destroying it and loosing all the back pressure ?
    If it comes down to it ill just spend the money on an aftermarket exhaust but like i said i like the look of the mufflers. If someone knows of a similar looking pair of aftermarket ones that will flow a little better and be louder please let me know.
  2. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    use a drill with a 1/4" big and drill some holes in the baffles
  3. invader_gir05
    how do i go about taking the stock mufflers apart to get to said baffles?
  4. invader_gir05
  5. RickCoMatic
    Hows the bike run? Good?
    Want it to start running bad?
    Mess with the exhaust!
    If you gut the Silencers and lose the Back Pressure ... you'll have to pull the Carbs and Re-Jet them!
    You might get close the first time.
    Maybe.
    Maybe not.
    You need to ask yourself an important question.
    Is having louder pipes more important than performance?
    Be sure to get the whole picture before you decide that Sound Effects are more important than Fine Tuning!
  6. Deathmetaldan
    Sunbury PA 17801
    you dont need to take them apart. just drill from the back of the pipe... shouldnt need a rejet either
  7. invader_gir05
    Thanks, but i guess ill just not bother with it at all...
    And Rick thanks but i didn't wanna completely gut them. I was just wanting a slightly more aggressive sound, nothing extreme. Thats what i was saying
    "What im wondering is if there is a way to make it slightly more free flowing and slightly louder without completely destroying it and loosing all the back pressure ?"
    But i guess ill just leave it b since ive already got to rejet for the po putting pods on the bike.
  8. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Invader,
    Take off the stock mufflers and store them in plastic for future use. Then go on Ebay and get a pair of tapered Harley mufflers and slip them on. You'll see what I mean. They sound sweeeeeet.
  9. invader_gir05
  10. Marko
    Marko Member
    Upstate, NY USA
    To make them more aggressive, don't feed them, then smack them up a bit, and make them square off against smaller, weaker pipes, and when they win, feed them and praise them. Whenever they are mean, let them know that's what you want. Rinse and repeat.
    Your pipes should be crazy aggressive in no time. :p
  11. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    LMFAO then ROTFL
    There are quite a few options avalible!!
    I have slip on jardines and I am hear from blocks away @ 5k rpms
    You could pick up some aftermarket pipes and experiment<only YOU know your tastes>
    Or if the originals are "disposable" you could completely remove the baffles.
    Then pick up some muffler packing from a muffler shop or online
    Pack your pipes and roll.
    Then you can add or remove packing as you see fit.
    The stock pipes are worth their weight in gold if they are in good condition.
    I think the aftermarket solution paid for by selling your "quiet" stockers.
  12. Jakob
    Jakob New Member
    Louisville, KY
    I might try the tapered Harley mufflers. The mufflers on my project XJ are smashed and rusty... not salvageable by any means. :cry:
  13. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    I've said this before, here goes.
    Some engineer sat for hours with computer, slide rule and test results and figured how to make these bikes run the way they do.
    Then come someone who thinks they know more than the experts.
    But then I'm not no engineer and really dont know nothing anyway...
  14. bigfitz52
    EDZACHARY!!! As soon as you start messing with exhaust or intake, you will upset the delicate performance balance designed in by those very same engineers. You will most likely DECREASE the overall performance of your machine in favor of a POSSIBLE SMALL gain somewhere in the power band. It all depends on whether you want to ride the bike, or spend literally hundreds of hours retuning it, only to come just close to how it was before. To me anyway, it's not worth it.
  15. Hack
    Hack Member
    Ontario, Canada
    I had heard about this drill trick, but it doesn't seem like such a good idea now.
    Do the MAC 4 into 1 exhaust systems create a need to re-jet and fine tune? I had those in mind in case mine went rotton.
    Thanks.
  16. Hack
    Hack Member
    Ontario, Canada
    Found my answer in other posts...should have done more research...
  17. rdbhere2
    rdbhere2 Member
    I removed the rear cap on my stock exhaust and the sound is awsome. nice throaty tone.
