Stripped thread in the engine block extensive oil leak
Discussion in 'XJ Technical Chat' started by matthew fitzpatrick, Aug 14, 2016.
  1. matthew fitzpatrick
    matthew fitzpatrick Member
    wirral
    So ive managed to litrally pull a thread clean out on the gear shift side casing causing an oil leak my plan is to fill the hole with chemical metal/jb weld / evo stick liquid metal drill it out then re tap a new thread into it has anyone had any joys doing this ?
    Don't do it that way.
    Use an insert.
    Helicoil.
    rocs82650, desmotom, DrewUth and 2 others like this.
  3. MiGhost
    MiGhost Well-Known Member
    While JBWeld is good. I highly disagree with the ability to hold threads to any torque. I have had it crack and pull apart.
    ~Ghost
  4. a100man
    a100man Well-Known Member
    Bedford, UK
    pictures please..
  5. Jetfixer
    Agree with k-moe a helicoil is the way to go , use good quality thread locker before you install , should be good to go. Make sure you use a torque wrench set to proper torque so you do not have same problem ( You may not have been the one who over torqued fastner usually Previous Owner or Moose Cholock at Stealer ship.)
  6. DrewUth
    DrewUth Active Member
    South Jersey
    Helicoils are easy to install and work very well.
    k-moe and Jetfixer like this.
  7. Polock
    agreed, but the first one you do shouldn't be in a side cover of your bike. practice once on something disposable
    rocs82650 likes this.
