Strong battery
Discussion in 'XJ Technical Chat' started by trekrider, Apr 14, 2009.
  1. trekrider
    trekrider Member
    lancaster PA
    How much effect does having a strong new battery help in starting the cycle?
  2. wizard
    It is essential to have a fully charged battery to spin the starter motor and give a healthy spark.
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    A weak battery will cause most of the amperage to be diverted to the starter, and away from the coils. Thus, as the bike is turning over there is not enough spark to get it to catch. If you ever notice that as soon as you take your thumb off the button the bike will fire, then your battery is probably low.
    Like Wiz said a strong battery is one of the most important components you can have! A weak battery can even do damage to your charging system.
  4. pictishusa
    pictishusa Member
    West Richland, WA
    Just a thought, i keep my battery on a trickle charger 1.5 amp i got from walmart for like 25 bucks has a quick connect to make it easy, its a schumacher, great for storing your bike or in the winter, keeps my battery fully charged wont overcharge.
  5. trekrider
    trekrider Member
    lancaster PA
    I replaced my old battery with a new one, now the bike seems run nicer, smoother, not to mention starts easier.
    Does this make sense that the cycle would run and idle nicer with the new battery?? I would only think that it would make starting easier.
  6. SQLGuy
    SQLGuy Well-Known Member
    Yes, it does make sense, as the alternator doesn't provide much current at idle,... so, if the battery is weak, the colis may not be getting enough power at idle for strong spark.
    Computerized engine management systems actually adjust coil dwell time based on battery voltage, but I don't think the TCI unit is smart enough for that.
  7. bigfitz52
    Correct on both points. The TCI is "first generation" all it does is provide the ignition/advance; no fancy "computerization" there.
    Further, since the charging system isn't doing anything below 2 grand, it is up to the battery at low RPM.
  8. switch263
    switch263 Member
    Austin, TX
    I have one of these. It WILL overcharge your battery. Just wait until you go out to the garage one day and hear your battery trying to boil because the 'fully charged' circuit on the charger kicked on, but it didnt kick OFF the charging circuit.
  9. tylernt
    tylernt Member
    Idaho
    Yeah, my Wal-Mart 1.5A charger boils my battery too. I first tried a solar cell in a window but just ended up with a dead battery.
    I'm thinking a trickle charger would have been a better choice.
