Stuck enrichment circuit valves
Discussion in 'XJ Technical Chat' started by cereal_killer, Mar 24, 2008.
  1. cereal_killer
    cereal_killer Member
    Baja Mason Dixon Line, East of Honolulu
    OK, so I'm stuck (literally) on figuring out how to extricate the enrichment circuit valves on my Mikuni BS33's #2 & #3 carbs. I really would hate to break another plunger or worse yet, deform the bore! :cry: Anyone else out there face a similar situation? Any success stories? Thanks in advance!
  2. chacal
    a) Penetraing liquid, overnight.
    b) heat on the area of the carbs surrounding the pistons....a tiny amount of heat, over a long period of time (let's say, 5 minutes), to gradually allow the aluminum to expand.
    c) cold (ice cube, etc.) held onto the brass plunger tip for a few moments to draw out all the heat from the brass plunger (allowing it to shrink, or at least not expand as much as the surrounding aluminum).
    d) a couple of gentle taps from a hammer on the plunger tip to loosen things as much as possible.
    e) Prayer.
  3. RickCoMatic
    You have to be VERY careful with HEAT on the Mikuni Enrichment Valves.
    The bottoms of the Valve Bodies have Rubber Seals.
    Take off the Rubber Dust Covers
    Use a 6-Point Socket to loosen the Bodies
    Impact the Ratchet Handle if the Bodies don't loosen ... they will.
    Shoot Carb Cleaner in the Bore.
    After the Carb Cleaner evaporates ... add Marvel Mystery Oil.
    Wiggle them out and turn them as you can until they come free.
    Refinish the Enrichment Valve Bore with 800 Paper rolled tight and twisted in the Bore.
    Follow the 800 with 1000
    Chuck the Valve into a drill and Polish the outside diameter until its brilliant shining brass!
  4. cereal_killer
    Wooooo Hoooooo!!!! Just got those buggers out this morning, and with no further damage! Thanks again for the suggestions!
  5. Jon81550Maxim
    Jon81550Maxim Member
    N.Ontario
    If you listen very, very closely, you can hear the little buggers say.....
    We surrender!!!
    Nothing better than a skirmish won in the morning.
    Walk TALL my friend, you put that Murrphy and his evil Laws in their place! :)
