Stuck oil drain and filer bolts/white sludge in oil
Discussion in 'XJ Technical Chat' started by ryanismyname, Jan 9, 2010.
  1. ryanismyname
    ryanismyname Member
    Baltimore, MD
    Both the bolts for my oil filter and oil pan are stuck on my 82 seca 750. I've put a 12mm open end wrench on the oil filter bolt, after soaking the back in PB blaster and I just start to round it.
    The oil pain drain looks like a 6pt 16mm? It's rusted and appears to be a replacement. Any tips for unsticking these?
    Also, there is a lot of white sludge in my crankcase. Would gasoline do that? I know some leaked in when the floats were set too high. Or is it more likely a ventilation/short trip problem?
  2. markie
    markie Member
    Suffolk, England
    I have yet to face this, but I HATE open enders! Try a good fitting socket or ring spanner.
    The only tip I have is to use the next size down - be it Metric or Imperial - and tap it on with a mallet. This gives a good fit on a rounded bolt head.
    I believe "Mayonaise" is a short trip/condensation issue when the motor does not really get hot enough.
  3. bigfitz52
    Yep, that white or cream colored residue is from moisture, whatever the source. Usually short-tripping does it especially in humid weather.
    If you even suspect the oil has been polluted with gas, change it.
  4. skillet
    skillet Active Member
    SW TN
    Mine started rounding (the small head, never changed out) and I tapped a deep well socket on the bolt, then used breaker bar while wife tapped on the end with hammer and got both of them off with no problem :wink: ...
    skillet
