Stuck oil filter bolt
Discussion in 'XJ Technical Chat' started by Bmgalena, Mar 14, 2018.
  1. Bmgalena
    Bmgalena Member
    Joplin
    Well crap. This sucks. Rounded off. Wont move with vice grips. Any thoughts? 20180314_170708.jpg
  2. SR500ED
    SR500ED Member
    Smithville Ontario Canada
    That bolt is toast. Perhaps grinding some flats on it and lightly tapping on it while turning with vicegrips. Worked for me, careful not to damage cases.
  3. Bmgalena
    Bmgalena Member
    Joplin
    Already got a replacement bolt. Was hoping to not use the dremel but looking like it might be the only way
    Grind the head off, then slowly grind though the flange (looks like a washer, but it's not) until the housing can pop free.
  5. SR500ED
    SR500ED Member
    Another good reason to go for the spin on filter conversion.
    Jetfixer likes this.
  6. k-moe
    Maybe. Filters can get stuck in place too, and I have had to cut one off before (it had been in place for about 40 years)
  7. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Weld a nut to the end of the bolt. Work it back and forth til it can be removed. I'd save grinding as a last resort
  8. SR500ED
    SR500ED Member
    Probably the best method if you have a welder.
  9. Bmgalena
    Bmgalena Member
    Joplin
    Its off!! And everything us back together. Took a bit with the dremel and a grinder. I did nick the housing but i think the oring on tge bolt is what seals it. Is that correct?
  10. chacal
    Correct!
