stupid question
Discussion in 'XJ Technical Chat' started by Gryfter, Sep 15, 2011.
  1. Gryfter
    Gryfter New Member
    first a brief explanation on why im asking this question.
    teaching my wife to ride she laid the maxim over at low speed
    bent handle bars and a broken clutch cover on the right hand side were the biggest of the damage
    do you need that cover?
    i think its called the stator cover. Do you need it?
    Ill try taking a pic and uploading it later
  2. MiCarl
    Stator is on the left side.
    On the right there are 2 covers. The larger one with the shiny circular insert needs to be intact or it'll spew oil.
    The smaller one ahead of it that has 4 screws holding it on is decorative only. So long as the case behind it is intact you should be ok.
  3. Gryfter
    Gryfter New Member
    yeah it is just that small one with 4 screws that took any damage
    cracked off case behind is fine =)
    thanks
