Surging On The Highway
Discussion in 'XJ Technical Chat' started by Doublebourbon, Aug 28, 2017.
  1. Doublebourbon
    Doublebourbon New Member
    US
    Hey everyone, a bit of an interesting issue with my bike.
    So you know what I'm working with:
    82 xj650rj 23k on the clock.
    Carbs spotless, synced, floats wet set
    Stock jets and stock air box
    No vacuum leaks
    Valves in spec
    Color tuned, plugs look good to me
    Petcock rebuilt
    New fuel line and filter
    Clutch lever properly adjusted
    New tires, properly inflated
    The issue is that I get a pretty significant bit of surging or pulsing when running in 4th or 5th at 7k+ rpm. When I hit the on ramp and give it WOT in 1st, the tach is smooth through the entire range, right up to red line, shift into 2nd and all is still good to red line, 3rd is the same, but when I hit 4th the problem appears. All is good to 7k rpm then it starts to surge a bit, struggling to move the needle, shift to 5th and surging is very noticeable, but I'm also then well above the 100 mph so back off. I'm a big guy, 230+ and not equipped with any type of aero package so I could be part of the problem.
    This shouldn't be a fuel delivery problem or I would notice it in 1st, 2nd and 3rd gear. I am leaning towards a slipping clutch, but everything is properly adjusted and my rpms surge, not the mph. Could this be caused by oil? I'm running 10w - 40 right now but have thought of switching back to Rotella T. We are down to about 2 months left in riding season before the snow blower will get more use, so I would prefer to leave the clutch alone until then unless it is vital to pull the cover.
    smeagol21b likes this.
  2. Polock
    it is the clutch but the clutch works in oil and it's easier to change the oil. go back to the Rotella and see what happens.
    the clutch and springs have been in there a long time, even if the oil fixes it you should think about a clutch rebuild
  3. XJ550H
    230 not a problem
    maybe slow down too
    10 40 oil what it your temps outside
    Doublebourbon likes this.
  4. Jetfixer
    ^^^^+2 What thy say sounds like clutch slip
  5. k-moe
    Clutch, and I doubt that an oil change will make it any better.
  6. Doublebourbon
    US
    Thanks for the confirmation that the clutch is the culprit. I'm not regularly running it that hard, but our interstate speed is 80 mph. Knowing that the clutch is going to slip when passing at that speed doesn't install much confidence.
  7. Jetfixer
    Replace not that expensive.
  8. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    Clutch replacement only takes an hour in your driveway.
  9. Doublebourbon
    US
    Alright, didn't want to be one of those people who ask a question, get great answers and disappears never to be heard from again.
    Swapped friction disks, springs, gasket, clutch cover to fix a scar and oil. Adjusted the cable per the manual's specifications. Getting really close to the flush oil change at 250 miles.
    The end results are being able to cruise at 80 to 85 mph, grab a fbit of throttle to make a pass. No stumble, no surge, no hesitation, just a smooth pull to passing speed before settling back down.
    Thanks all for the help
    jayrodoh, k-moe and Stumplifter like this.
