Switches & starting for 81 XJ550 Q?'s
Discussion in 'XJ Technical Chat' started by Sammowry, Feb 15, 2006.
  1. Sammowry
    Sammowry New Member
    Vancouver, WA. USA
    Background - I’ve rescued a 1981 XJ 550 from a barn. It has been in the barn for 2 years, but P.O.(previous owner) claimed it did run last summer(6 to 8 months ago.) It is missing parts & pieces, but mostly cosmetic. The weather in my part of the world is winter, cold & rainy right now, so I haven’t been doing much wrenching. When the weather clears I will attempt to start the engine & get it running.
    I’ve won an older Clymer repair manual on Ebay for a small price, & it arrived a few days ago. I've been turning pages and looking up the simple stuff - capacities, tire pressures, spark plug gaps, etc. I went to the wiring page - here's were my questions start - mostly about the starting proceedure for the XJ.
    A) Micro switch at the clutch - does the clutch need to be "held in" when starting? My Kawasaki 550 is this way - even if the bike is in neutral, you have to hold in the clutch lever or the bike will not start.
    B) Side stand (kick stand) switch? Is this a "idiot switch"? (my ridin' buddy calls them that.) What use is it for, how does it "notify" you that the side stand is down, is it another cut off switch - meaning bike won't start with the stand in the "down" position?
    C) Does the XJ CD come with "owners manuals?" The little booklets that usually cover the most basic information - start proceedures, basic how to operate the bike, signal & warning lights & what they mean, etc.
    Example: on the Kawasaki - if the rear brake bulb has a broken filiment - the "brake warning light" in the gauge will flash or blink - telling the operator that there is something out of order. This little tid bit of information is generally not covered in the Clymers repair manuals - only the owners manuals or word of message boards - KzRider.com or XJ bikes.com
    P.S. I dug a little deeper in the Clymers repair book, under a section "starter curcuit", & found "starter relay cut-off." This section gives the 3 switches - Neutral, clutch & side stand (kick stand), & that the bike must be in Neutral, or the clutch lever held in AND side stand up BEFORE the bike will start.
    I guess I answered my own questions - but if there’s something else I'd appreciate any replies good or bad.
  2. woot
    woot Active Member
    A) I don't think it does - but it doesn't hurt. (Mine doesn't) (Ah - the ps answers why - I always have it in neutral starting, with the clutch in)
    B) Idiot switch - or safety switch. I have on occassion left the side stand down and started moving - holy hell does that give you a scare... it usually happens when you break up your routine. It can be VERY VERY bad to do and has cause some serious accidents ( riding with the side stand down)
    C) I think so - but I'm not an XJ CD owner - I do know that it is very comprehensive and certainly worth the ~10$
    have fun - woot!
  3. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    Welcome aboard.
    The xjcd does include the owners manual and service manual. Not just for your bike but for all xj's. Lots of other good info, tips , and tricks.
    Like Woot said well worth the $10.00.
  4. Carlos gonzalez
    Carlos gonzalez New Member
    Venezuela
    Buenas tardes amigos yo compren una xj700x y tiene dañado el rele del arranque y el rele del caballete y no prende quería saber si hay alguna manera de prenderla vi un video donde hacen un by pass y prenden un suzuki dr si alguien me puede ayudar se lo agradezco
