switching turn signals
Discussion in 'XJ Technical Chat' started by uzivelli, Sep 13, 2008.
  1. uzivelli
    uzivelli Member
    florida
    i am switching out my turn signals. the front left will come on and stay on with no blinking while the back one won't come on at all.
    what might be causing this?
    as i attempt to switch out the lights (three total), is it as easy as connecting the two wires? what should i know to do it right?
    thanks for the help, anyone.
  2. TIMEtoRIDE
    If you are getting rid of the factory signals and their 27 watt bulbs, and going to Chinese turn signals and 23 watt bulbs, then you need to buy a cheap automotive flasher to make them work.
    If you are replacing with Yamaha parts (3 total??) then just connect the wires, and troubleshoot the one that didn't work. Buy a multi-meter.
  3. uzivelli
    uzivelli Member
    florida
    thanks. got them working! would you know it, i opened the signal that wasn't working and it was deteriorated beyond help and was garbage. the caveats of ebay!
  4. bill
    bill Active Member
    Raleigh, NC
    I had a similar issue - a bad ground on one of the lights.
    I think you can get a new socket to replace the garbage one if the casing is good
