tach guage needle barley moves ?
Discussion in 'XJ Technical Chat' started by jonnymaritime, May 21, 2008.
  1. jonnymaritime
    jonnymaritime Member
    Montreal QC
    it moves but barley ?
  2. skoobasteve
    skoobasteve New Member
    Philly
    Running, Cranking or What?
  3. RickCoMatic
    Pull the Instruments and take-out the tach.
    Look at the back of it.
    There's a Brass Bearing Bushing
    Clean it with alcohol
    Carefully "Flick" the indicator as you do.
    Put 1 (One) drop of WD-40 on it.
    Move the Indicator Needle a few times.
  4. jonnymaritime
    Montreal QC
    thanks Ill try that .
  5. schwarztrader
    schwarztrader New Member
    Hillsboro, OR
    I have this very same issue on my 82 XJ750J. I decided to crack open the instrument panel and take out the tachometer but I couldn't figure out how to get the tach out of the panel to perform the maintanance. I'm sure i'm just missing something very simple - Any suggestions?
  6. RickCoMatic
    You have to remove the cover and undo all the screws.
    You have to undo the screws that the wiring harness attaches to the back of the Tack; too.
    Mark them or make a drawing.
    Once the wiring harness is removed there are two mounting screws to release and the instrument comes out of its bezel.
  7. schwarztrader
    Hillsboro, OR
    Thanks for the info as I was able to get the tach out by taking the 3 screws that held the Black, Grey and Brown wires to the back of the tach. I then cleaned the back of it with alcohol (it looked clean as a whistle even before I started) while flicking the indicator a couple of times. I then put one drop of WD40 in there and flicked the indicator once or twice more. I then put everything back together and started up the bike. In idle, it still barely moves when I rev up the engine with the throttle. Does the bike have to be moving down the road for the tach to work?
    NOTE: I am still having issues with the blinkers, horn and LCD warnings not working. - This all started the same time my tach stopped working.
  8. schwarztrader
    Hillsboro, OR
    The tach started to work (along with everything else) when I decided to solder the connections to the blade-style fuse box instead of using crimped on connectors.
  9. Robert
    Corrosion strikes again! You have been throughly initiated now, welcome to the club.
  10. bluepotpie
    bluepotpie Member
    Londonderry, NH
    I had the same problem with mine a few years ago when i pulled the bike out of it's 15 year resting spot in the woods. I was pulling my hair out trying to figure out why the electrical systems were working poorly. Turned out to be a corroded ground! Sometimes we get so involved with the complexity of the system that we forget about the simple things we need to check first.
