Tach just stoped working and turn signals
Discussion in 'XJ Technical Chat' started by smokeys81, Jun 21, 2011.
  1. smokeys81
    smokeys81 Member
    SW Michigan
    The bike ran ok this morning and tach worked fine turn signals also worked. Now they both stoped working completely Lost what to do Thanks
  2. bigfitz52
    Start in the fusebox.
  3. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    the tach runs off the 10a "signal" fuse. Do as Fitz says and 10 to 1 says you end there too.
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    Check battery. Slow cranking? Could be on its way out.
    If so, could also be the generator getting weak.
  5. smokeys81
    smokeys81 Member
    SW Michigan
    The Battery is good for sure because i gave it a full charge and fluid level is high. When I was taking the battery in and out I thought I disconnected a connection for something because there was a open plug socket so i looked for the other side of the plug and thought I found it under the engine connected it a tri-pod looking plug, and now the bike is getting no juice nothing at turn of the key. Back to the drawing board in the morning. Thanks for any help or suggestions
  6. RickCoMatic
    You need to have a "Test Light Festival"
    Sometimes they're over before you get to finish the first beer.
    Other times, they go-on for hours, because of things you have to deal with being especially foo-bar. (F.U.B.A.R.)
    Having a Test Light that's fun to use takes some of the tediousness out of the job.
    Taping a strip of Leather to your Finger will help speed things up.
    (You don't hesitate stabbing a Wire when you know your Finger ain't getting punctured with the Probe.)
    Eleven Dollars and Ninety-nine Cents
    $11.99
    The World Famous ...
    Cal-Van #72 Test Light with Sounder.
    http://cgi.ebay.com/ebaymotors/Circuit- ... 0480799920
  7. waldo
    waldo Member
    San Jose, Ca. 95125
    What color where the wires on the tripod looking thing?
  8. smokeys81
    smokeys81 Member
    SW Michigan
    The three prong plug I think was yellow the bike will do nothing now i tried to post a pic but the pic was to big to attach I'm dead in the water.. The battery is fully charged all conections look solid fuses are good from there I dont know what to do and I'm on a tight budget and I've been doing nothing but dropping money in it help
  9. bigfitz52
    Step 1: UNPLUG whatever it was you plugged in that made things worse.
    Step 2: LOOK IN THE FUSEBOX.
    Step 3: Get a manual and figure it out; just plugging stuff in because you think "it goes there" is a way to spend a whole lot more money unnecessarily. Just poking about and guessing will cause problems not solve them.
    Which DOES NOT mean the battery is fine; it means it has water and you charged it, and that's all. Take the fully charged battery to an auto parts store and have it load tested; then you'll know "for sure."
  10. smokeys81
    smokeys81 Member
    SW Michigan
    Your right I understand that and I do have a repair manual. The owners which is probably several has chopped up this bike pretty bad only has two original fuse slot the rest are bypassed and nothing looks original just rigged up. So I think a complete overhaul of the bike is due which would be a great learning experience..
