tank swap
Discussion in 'XJ Modifications' started by santos750, Nov 18, 2012.
  1. santos750
    santos750 Member
    winnipeg manitoba canada
    hmm..will an '82 virago 750 tank fit on my '83 maxim 750? just got a lead on a mint tank, curious if the frame is wider on the virago.
  2. MiGhost
    MiGhost Well-Known Member
    The frame is actually wider on the maxim. The virago tank will need to have the tunnel clearanced to fit on the maxim frame.
    I believe there is also a difference in the mounting points between the tanks.
    Ghost
  3. maverickbr77
    maverickbr77 Member
    Lowville, New York
  4. hogfiddles
    Won't fit without a fair bit of work. The tanks look similar but there is a lot of interference as the underside of the Virago tank is much narrower, the mounting points are a bit different, and when all is done, the wider flatter front of the virago tank may interfere with the triple top. Haven't checked that spot yet because I can't hold the tank in far enough to check.
    dave
