Tear down begins!
Discussion in 'XJ Technical Chat' started by pianomangg, Oct 24, 2008.
  1. pianomangg
    pianomangg New Member
    Calgary, Alberta
    Hi all,
    Been awhile since I've been around. :oops: Resurrected a EX500R from a salvage yard, and it pulled attention for the last couple of years. That, and life keeps getting in the way of my 750 rebuild. But have a house with heated garage now, so the fun began tonight!
    The plan is to completely tear down the Seca and rebuild it. I've had the Seca since summer 2001, and since that summer it's been one problem after another. Just get something fixed, something else goes 20 miles later. The major overhaul was finally precipitated by an ongoing starter clutch problem that just won't go away. It's left the bike sitting for over two years now as none of the simple fixes worked. If I have to pull the engine to fix the s.c. properly, why not just take care of everything and enjoy some miles on this thing?
    Nothing too heavy tonight: stripped the body work and tank, and then removed the exhaust system. So far, so good! This is going to be a slow process with no deadlines... want to enjoy every turn of the wrench and overlook nothing.
    Thanks for reading!
    GG
  2. Zookie400
    Zookie400 Active Member
    Connecticut
  3. pianomangg
    Calgary, Alberta
    Including pics, per request....
    From the look of the collector box, there's an oil leak in the bottom of the engine, somewhere...
  4. wizard
    Hi, the last pianoman was a real diamond, I hope you enjoy the rebuild, here's a picture of my bike reduced to it's lowest common denominator. Wiz.
  5. bobwinkel
    bobwinkel Member
    Portland Oregon area
    Thats quite a pile of parts. Looks like you are missing the whatsit rod though.
    Lots of luck and keep the pix coming/
  6. jswag5
    jswag5 Member
    Saint Joe, IN
    i just started my tear down today, got the full front end removed, took the tire off of the rim, got the rim soaking in a tub of solvent, gunna repaint it before i put my new tire on, put the tire i took off the rim onto my honda, it fit like a glove, now no more filling up the tire every few hours while riding!
  7. knghtwolph
    knghtwolph New Member
    Atlanta Ga
    I wish I had the time to tear mine down that way but its my only ride. I wanna know where you got the fairing and where can I get one?
  8. wizard
    wow, that takes some doing!
  9. pianomangg
    Calgary, Alberta
    Been lucky... both my Secas (750s) have come with the fairing. This one didn't have the windscreen, but got even luckier when a NOS screen came up on Ebay. Trouble is, they're so fragile! At some point during this rebuild, I want to use the windscreen to make a mold and see if I can make duplicates. Never know when they'll come in handy!
    GG
