The Seca other drive specs
Discussion in 'XJ Technical Chat' started by HooNz, May 31, 2006.
  1. HooNz
    HooNz Member
    No workshop manual as yet , but i'd like to know the freeplay/backlash/mesh specs on the drive , and no not the drive at the rear wheel , the other drive in the motor , "the output shaft" , it has adjusting shim spacers there and my thing has one shim but in looking and checking [all pulled apart] the mesh , it has none , and it looks like it is meshed too hard in what i see on the spiral teeth faces , so peoples can anybod help?
    So , i after the factory amount of freeplay if any between those 2 gears please...
    thanks in anticpation........
  2. Nick
    Nick Member
    Vernon, BC Canada
    for the output shaft of the engine, where the u-joint attaches
    gear lash: 0.1 - 0.2 mm ( 0.004 - 0.008 in. )
  3. HooNz
    HooNz Member
    Thanks a heep Nick.......
