Thinkin about 82 Seca XJ750 have ?s
Discussion in 'XJ Technical Chat' started by edvol, Aug 13, 2016.
  1. edvol
    edvol New Member
    texas
    I am thinking about getting this it has 9000 miles on it
    Last ran in 2005
    Carbs were rebuilt in 2005 and new tires and new exhaust.. but owner stopped riding bike when he noticed rust in tank .. he said he tried to get rust out of tank but botched sealing job and just parked it
    Its a one owner bike always kept inside
    My ?s are is gas tank expensive to redo and I guess carbs need redone also
    Also someone told me these engines got week and started to go at 40k miles is this true?
    First: the engine is good for well over 100,000 miles and likely far more than that.
    Secondly, redoing the inside of the tank will depend on what liner was used, but it's not terribly expensive; about $75 in materials (far less expensive than finding a good used tank).
    Thirdly the cosmetics look ot be excellent and that is very low mileage, but you will need to go through the machine thoroughly before considering it to be road worthy.
    Homework:
    TECH TOPIC: The Real Costs of Maintenance
    The Information Overload Hour
    Stumplifter likes this.
  3. edvol
    edvol New Member
    texas
    More pics
    Jetfixer likes this.
    It's missing the tank badges, but I can tell you that if I had the cash to spend I'd be making an offer on it myself.
    My only concern is the state of the alternator chain guide. Be aware that it will eventually fail. Most seem to be failing due to a combination of use and age, but that one may have more life in it since the miles are low and it's been stored inside. Unfortunately the alternator chain guide can only be replaced by splitting the crankcase.
    I would doubt the mileage if it weren't for the condition if the gauges. No fading at all; not even the needles.
  5. edvol
    edvol New Member
    texas
    He has the tank badges
  6. edvol
    edvol New Member
    texas
    I called a place here they want 400.00 plus the carb kit price to do the carbs
  7. k-moe
    You will be taking care of the carbs (and all other maintenance) yourself, for far less than that. If you feel uncomfortable, or don't have the time, Hogfiddles rebuilds carbs for a reasonable cost (again, far less than a shop).
    Generally speaking, shops do not do nearly as good of a job as we can help you do.
  8. edvol
    edvol New Member
    texas
    Hogfiddles??
  9. edvol
    edvol New Member
    texas
    He wants 1400.00 for the bike and is firm
  10. chacal
    "Firm" means you have to wave a stack of 11 or 12 benjamins under his nose, in person............and be ready to stuff them back in your pocket if he says no!
    Stumplifter, k-moe and Jetfixer like this.
  11. Jetfixer
    Bike looks very good...if you do buy it a couple of tips...DO Not hack it into a bobber it looks like it is in fantastic shape. Do Not take off stock airbox and put pod filters on they are not worth the trouble. Go though the brakes front and rear , check the date codes on brake lines, and tires more than 5 years old replace ( brake line probably 1982 vintage) replace fuse block if original glass fuses , blade type fuse block recommended. Check and adjust valves as needed... clean and fully rebuild carbs IE new throttle shaft seal, gaskets, needle and seats. New good quality battery, and oil and filter change( recommend upgrade to spin on filter kit from xj4ever did it to my xj750 seca) .
  12. edvol
    edvol New Member
    texas
    what about clutch...sitting so long dry
  13. k-moe
    replace. Well tell him that anyway, but it might be fine for a few more miles.
    As far as I know mine's still on the original clutch (north of 27,000 miles). I keep thinking that I should replace it, but it keeps not slipping at all, so I don't bother to put a new one in.
  14. Jetfixer
    Unless clutch is slipping it is usually ok ... you can also adjust if milage is as low as stated should be ok . Highly doubt it would need replaced.
  15. hogfiddles
    That would be me.... And currently I charge HALF that ..... Send me a private conversation and we can talk.
    Engine going weak at 40K?!? Maybe for someone who doesn't know anything about them, or doesn't take ANY care......or it was a shop that told you that------they don't know much about these, either......lol
  16. edvol
    edvol New Member
    texas
    Since he has already put a liner in tank...but says he botched the job ...can it be redone?
  17. k-moe
    Yes. MEK will eat the old liner out.
  18. edvol
    edvol New Member
    texas
    just pour in soak pour out
  19. k-moe
    Caswell is the lining kit that I recommend. They have instructions that goes into more detail about how to prep an already lined tank, but essentially that's it. How long you soak will have a lot to do with what the liner material is. Be sure to work in a well ventelated area (outdoors preferably) and wear the appropriate PPE. MEK is about the nastiest solvent there is.
    MiGhost and Jetfixer like this.
  20. edvol
    edvol New Member
    texas
    Anybody here that can do this for me? I pay
    Send tank
  21. RonWagner
    RonWagner Member
    $1400 is a good price for a bike that clean. You could hand him $1200 and see if he keeps it but I wouldn't cheap out and walk away over $200.
  22. MiGhost
    MiGhost Well-Known Member
    And it has about a 99.99% chance of destroying the paint on that tank if not handled extremely carefully!
    What a shame!!
    ~Ghost
  23. k-moe
    Yes, that is a risk. It's a shame that tank liners used to be so crappy.
    I wonder how much of it can be peeled or abraded out without resorting to MEK until the very last.
  24. MiGhost
    Only Caswell, and Por15 are any better now, They are the only sealers that I would trust.
    Not sure if a 40% muriatic (pool cleaner) soak would remove creme sealer.
    If it is the Creme sealer (white, rubbery). Media blasting might remove it. Depends on the blaster.
    I would follow this with a 20% phosphoric (MSR) soak as long as there were no signs of pin hole leakage.
    ~Ghost
  25. Jetfixer
    I have used Red Coat with good results.. years ago used kreme worked good . But ethonal was not as used as much then either.
  26. k-moe
    You got lucky.
