Thinking about new tires...
Discussion in 'XJ Technical Chat' started by Theemarkmiller, Aug 12, 2014.
  1. Theemarkmiller
    Theemarkmiller New Member
    Westminster, MD
  2. MiCarl
    "H-rated tube type" These tires require a tube.
    If you really plan to ride the motorcycle you might consider THESE. Modern tire, but with a more classic tread pattern.
  3. bigfitz52
    +1.
    MUCH better choice.
  4. MBFTY
    MBFTY Member
    Lumberton, NJ
    Just scooped up a set of Bridgestone Battlax BT45 from Dennis Kirk. $201 shipped, and thats for Bridgestone Sport Touring tires.
  5. k-moe
    +2 on the retroactives. I haven't run them, but the first tires linked to are meant for pre-1970 motorcycles. The tread pattern isn't reminiscent of tires used in the 80's. You can't run a tubed tire in a non-tube rim because the bead is different. A tube tire won't lock into the bead of a non-tube wheel.
  6. Rsk_141
    Rsk_141 Member
    Scotland
    Seen These Don't Know if Anyone has Fitted Them.
    Conti Classic Attack
    But They Seem Good On Paper
  7. warthogcrewchief
    warthogcrewchief New Member
    Alvin, TX, USA
    When I rebuilt my CB350, I heard of a few guys with all sorts of CBs using Shinkos. They said the tires ride well and felt like a quality tire. Shinko bought the Yokohama tire plants...basically the same as Yokohama. Also heard some guys running them on their Venture with positive results.
  8. thejewishguy
    thejewishguy Member
    Miami
    I run Kenda tires.. Great chinese tires... Even my Nike running shoes are made in China.. My girlfriend was also Made in China !
  9. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Or......
    Have a look at the Shinko 777's. They have a whitewall option on select sizes.
  10. Kickaha
    New Zealand
    That isn't correct, there is normally no difference between the bead shape on a tubed or tubeless tyre
  11. TIMEtoRIDE
    I heard that tubeless tires have a special air-tight rubber layer on the inside, and tube-tires don't, which means they will always leak air without a tube.
    Adding a tube adds weight, cost, and friction.
    Go tubeless!!
    (how come my Yokohama tires are Made In USA ?? )
  12. Polock
    I may cut loose for those Conti classic next time, just because their radial and I remember
    What radials did for cars back in the day.
  13. warthogcrewchief
    Alvin, TX, USA
    Good question. The information I found regarding the Shinko tires was about five years ago. It could be the Shinkos are a copy of Yokohama tires. Last I heard, Yokohama went out of business a few years back.
  14. MiCarl
    My objection wasn't to the Shinko brand, it was specific to that tire:
    1) The tread design is way out dated. You'd get much better handling and performance from a modern tread.
    2) As TIMEtoRIDE pointed out, tube type tires do not have an air tight lining and need a tube. That tube adds heat and is more likely to rapidly deflate if you puncture it.
  15. Polock
  16. k-moe
    In my experience there is a difference. To run a tube type tire on a tubeless rim you have to use a tube in order for the bead to seat.
  17. warthogcrewchief
    Alvin, TX, USA
    Yes, from what I understand Yokohama stopped making m/c tires a while back.
