Throttle shaft seals alternative
Discussion in 'XJ Technical Chat' started by Henkies, Jul 10, 2014.
  1. Henkies
    Henkies Member
    The Netherlands, Europe
    Hi,
    I took apart my carb rack and want to replace the throttle shaft seals.
    But they appear hard to find. I read somewhere here that XJ4Ever sells x-rings instead of the genuine seals. XJ4Ever doesn't sell to outside the US, whereas I live in the EU.
    The shaft is 8mm and the bore is 11.35mm, which might count as 12 when the engine is hot. The only x-rings I can get here have an inner diameter of 7.60mm and are 2.62mm thick. I'm affraid I compress them too much when I install this size.
    Another alternative is this kind of seals. But it is not intended for high vacuüm or pressure. However the genuine seals aren't stiff either. So might this be a decent replacement seal?
    http://www.skf.com/group/products/seals ... rial=false
    Any other thoughts?
  2. bigfitz52
    Since when does XJ4Ever not sell outside the US?
    Len sells the correct seals, which are an unusual X-ish profile.
  3. Henkies
    Henkies Member
    Sorry, misunderstood! At several places I read 'cannot (and will not----don't even ask!) be shipped outside of the continental USA'. But this only applies to certain fluids. OK, I'll contact him...
  4. Polock
    #11 oring .301 X .441 two per seal,
  5. Bushy
    Bushy Active Member
    So Polock.. the orings ..is that what you have in your xj, what type of material are they and how long have they been in the carbs, I take it they do the job
  6. biggs500
    biggs500 Active Member
    Sherwood WI
    Len's seals work perfectly. I've used then in 3 racks and have not had a problem.
  7. Polock
    I don't keep track of years but pictures in the gallery show "09" , I really feel old now.
    Their Buna-n, regular o-rings.
    Their in there now. I had the carbs off this last winter , just to check them out,
    The o-rings looked good,
    The OD is a bit small as Henkies and I measured so these seal on the shaft and back wall of the cavity.
