tips on emulsion tube removal
Discussion in 'XJ Technical Chat' started by 1985xj700, Aug 27, 2008.
  1. 1985xj700
    1985xj700 Member
    Fredericksburg, Virginia
    I haven't been able to remove the emulsion tubes from my hitachi carbs. I remove the upper parts (diaphragm, needle, etc..) and the main jet on the bottom end. Tapping doesn't budge the emulsion tube (this is the brass tube underneath the main jet right?). Pushing with my finger from the main jet side doesn't budge it either. I am afraid to push with any tools for fear of damage.
    Does any one have any tips to free/remove emulsion tubes?
  2. MiCarl
    Thread a 5mm bolt in in place of the jet. Then you can tap more vigorously without fear of harm. You also might squirt some carb cleaner through the air jet to get the crud dissolving.
  3. 1985xj700
    1985xj700 Member
    thanks. i'll give that a shot next time I have'em apart.
  4. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Use a wooden dowel, tap it with a light hammer.....
    It soft enough not to damage the brass and hard enough to take a hit
