Tips, tricks, or suggestions on getting value shims out?
Discussion in 'XJ Technical Chat' started by sable_twilight, Aug 30, 2014.
  1. sable_twilight
    sable_twilight New Member
    Denver, CO
    I am follow the guide here:
    http://xjbikes.com/Forums/viewtopic/t=14827.html
    (Thank you for this Fritz)
    I am using the valve shim tool purchased through this site and I am still having a bear of a time popping the sims out.
    Are there any tricks or suggestions the more experienced mechanics might have?
    Thank you
  2. razz1969
    razz1969 Active Member
    Cleveland, Tx
    Get a can of compressed air from your local office supply. put a rag over your (engine) head and aim the tube from the can into the little slot on your shim bucket. Pull the trigger, then have a "why didn't I think of that" moment.
  3. k-moe
    Pop the shim up with a small screwdriver that has been ground into a chisel shape, then extract the shim with a magnetic device like this:
    Despite the usual claim, merely touching a shim with a magnet for extraction will not magnetize the shim (they are not made from the sort of steel that magnetizes easily, or permanently)
  4. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I thought you weren't supposed to use anything magnetic on the valves??
  5. Xjrider92117
    San Jose Ca
    O I didn't see the bottom line. :D 8O
  6. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I used a piece of 18G wire. They wouldn't come out one way, so I pushed them out the other. Doing valves on the bike wasn't nearly as hard as I thought it would be.
  7. Xjrider92117
    San Jose Ca
    It just sounds scary "doing the valves"
  8. sable_twilight
    Denver, CO
    Yeah, I thought the valves would be scary, but this project has been less overwhelming than I thought it would be. Sure, it's claimed some blood (scrapped a finger turning crankshaft) but I consider that a good sign.
    Now the carbs, which is my next project after the valves, those seem a little overwhelming.
    And to be clear, getting them out once they are popped is not the issue. I have a set of needle nose pliers which seem to have worked well on the two shims I was able to get out. It's the popping them up enough to get to them with the pliers is where where I am having the difficulty.
    I've give the above suggestions a shot on Monday after I rest of from my Sunday 24 hour shift.
  9. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    The buckets have a little spot to slip Little screw driver and pop the shim out, tkealook and you can spin the bucket with the screwdriver u til you get it in the right place.
  10. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    In the slot Ecologito referred to, I use the largest Jewelers Screwdriver and a pair of angled forceps that clamp. Sometimes I had to gently tap the screwdriver with a small hammer to "pop" the shim up. Just remember brute force will equal new problems that it creates. Take you time, don't get frustrated.
    Hope this helps...
  11. maxim-man
    maxim-man Member
    ontario canada
    Yup, right there!
  12. hogfiddles
    Sable,
    Sometimes the shims ARE really tight in the bucket (not the clearance, the diameter.....) and so you just have to work at it. Others pop very easily.
    I use a very thing screwdriver that fits the slot and the gap under the shim edge and then tap it with a hammer til it pops.
    Sometimes there just isnt enough clearance, so I have to tap the shim back down a bit and rotate the cam to push the bucket back down. I do that to get the the zip-tie in a bit farther to hold the bucket down a bit farther. That gives me the added clearance to get the shim to pry up far enough.
    You just gotta work at it......I haven't had one I couldn't remove yet......
    dave
  13. Polock
    if someone put a ding in the edge of the bucket trying to get the shim out they can get stuck half way out, use a bigger tapper.
    make sure you don't put any dings in it, all the prying and tapping is done at the notch only
  14. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Sable,
    Dave's suggestion is valid for using the 'zip tie' method of holding the bucket down.
    Use EXTREME caution if you are rotating your cams with the 'valve shim tool' attached to the head.
    If you rotate your cam into the tool there is a good chance of cracking your head . . :cry:
  15. EskimoJoe
    EskimoJoe Member
    Orlando, FL
    Just a reminder, as he doesn't say what bike he has, if he has an X, none of these good suggestions will do him any good. Changing shims in an X is an all day process at best.
  16. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Stuff the cam chain tunnel with rags to prevent a freak accident that includes a shim down the hole. Might try a old pair of tweezers to remove the shims (works for me).
    Gary H.
  17. FtUp
    FtUp Well-Known Member
    pacific northwest
    being that he is following fitz' guide, I am pretty sure it is an xj. good point though.
    CN
  18. sable_twilight
    Denver, CO
    Got them. Thank you all for the suggestions.
    Oh yeah, XJ550. and yeah, it was an all day project. But that's okay.
