Tires
Discussion in 'XJ Technical Chat' started by wbaize, Sep 10, 2008.
  1. wbaize
    wbaize Member
    Edinburg, TX
    Ok working on the tires, question tubes or tubless?
  2. Wombat
    Wombat Member
    Central Jersey
    Tubeless.
  3. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
  4. Danilo
    Danilo Member
    Vancouver canada
    Tires Are tubeless. But yr Rims may not be. It Says what they are on them.
  5. xj650ss
    xj650ss Member
    Calgary, Alberta
    tubeless unless your rims have spokes then u likely have tubes although i don't know if any xj's came with spoked wheels? but we will ask that question on another forum!
  6. bigfitz52
    Hi wbaize we need some info about your bike to be able to give you any helpful advice. Make up a 'signature' with your bike info it helps everyone else. Tire-wise I can tell you I have new Dunlop D404's on my '81 Seca and will probably use those or Avons when I replace the tires on the '83. If you're a Maxim rider then someone else will need to chime in.
  7. flash1259
    flash1259 Member
    W.R. Wisconsin
    82 Maxim 400 here, mine has cheng shin tires I beleave are the 2nd set its ever had. , I was told to get dunlop 404s mine has tubeless rims (aluminum) I can use both tubed and tubeless.
  8. wbaize
    wbaize Member
    Edinburg, TX
    well my bike is a XJ750, I currently have tubeless, I was just wondering if I could use either, I guess replacing them with tubeless would be best. Any suggestion on type or brand?
  9. bigfitz52
    Maxim or Seca, it MIGHT make a difference in choices on a 750. I can vouch for and recommend Dunlop D404's.
  10. 85MaximXX
    85MaximXX Member
    S.W. michigan
    another vote for the dunlop D404's I have them on my Maxim X and all is well even in the rain they hold the road well.
  11. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    That is what I run on my 82 750 Maxim
