trany promblem
Discussion in 'XJ Technical Chat' started by Diver14_98, Aug 12, 2008.
  1. Diver14_98
    Diver14_98 New Member
    fairview hgts il
    i have a 1980 xj 650. the problem is it acts like 5th gear isn't there.
  2. MiCarl
    Does that mean that shifting to 5th seems to go into neutral? Can't lift the lever after shifting into 4?
    Or, does shifting into 5 not lower the RPM much from 4 (normal)?
  3. Diver14_98
    fairview hgts il
    i can only lift shift lever about 1/4 of the way up. does not go into a neurtal it just does nothing
  4. switch263
    switch263 Member
    Austin, TX
    jumping to conclusions here, but i'd venture bent/overly-worn shifter fork or piece of the primary chain guide wedged in there?
