Turn Signal Switch
Discussion in 'XJ Technical Chat' started by Madone1, Dec 29, 2008.
  1. Madone1
    Madone1 Member
    Should I be concerned that my turn signal switch doesn't move as freely as it used to? Is it possible to "lube" it. I apologize for the dumb question but I thought I should seek some expert advice before I bust out the spray lube.
  2. bigfitz52
    I would strongly recommend careful disassembly and cleaning, then lubricate appropriately upon reassembly. Yamaha control pods are actually quite simple inside and can be taken apart and repaired effectively. I wouldn't just spray something into it, you could make matters worse.
  3. TheHound
    TheHound Active Member
    Scotia, NY
    I cleaned the inside good then used dielectric on the connections.
    It freed up my horn and turns signal so it moves smoothly.
  4. kd5uzz
    kd5uzz Member
    Never a dumb question. I have a similar problem. It all started when I used some contact cleaner inside my switch housing. I think I may have also bent some of the contacts. I to am interested in the responses to your question.
  5. Madone1
    Madone1 Member
    Once again, this forum provided the help and support I needed to fix this. It was really easy. Just removed the screw from the turn signal switch, popped the button off, and I was able to get my nozzle in there from my spray lube. A couple short shots and it is moving smoothly again. Thanks again, everyone at xjbikes!
