Ultrasonic carb cleaning
Discussion in 'XJ Technical Chat' started by gitbox, Nov 23, 2009.
  1. gitbox
    gitbox Member
    Does anyone think using an ultrasonic bath to clean the slide/diaphagm assembly would hurt the thin rubber?
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    don't do it. the slides are delicate and the rubber may or may not stand up to the chemicals in the ultrasonic bath.
    diaphragm rubbers can be cleaned with dish soap. the slide itself -- a rag with a bit of carb cleaner. do not use abrasives on the slides -- they have a thin layer of teflon-type coating..
    when you're done, apply some meguiar's natural shine or armor-all on the diaphragm rubbers....
  3. gitbox
    gitbox Member
    Thanks for the response, Stereomind. I like the Armor-all idea.
    I should have mentioned that the solution I use is mostly water with a little lemon juice and dishwashing liquid added. Pretty mild stuff. I am mainly concerned with the ultrasound agitation - if that does something to rubber.
  4. schooter
    i dont know if the agitation would hurt it, if the rubber is in good shape it seems to be pretty tough... but i dont know
  5. stereomind
    Tulsa, OK
    If you're using mild soap, I don't think the agitation would hurt either. I was more worried about the type of chemicals that you might be using in the bath. I'd still do them by hand, but I guess everybody's got their style :)
  6. NJRIDER1
    NJRIDER1 Member
    southern, NJ
    glad i read this post, i was going to get an ultrasonic bath from harbour freight just to use for carb and small part cleaning... maybe i'll hold off on that purchase.
  7. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    worked beautifully on mine!
  8. stereomind
    Tulsa, OK
    NJRIDER, we're only talking about the slides here, since they have a non-removable piece of rubber. For the most part, ultrasonic cleaning works quite well for the metal bits, so go right ahead!
    As for rubber pieces, make sure whatever chemical you're using is rubber-safe...
  9. bigfitz52
    Personally I'm a big fan of old toothbrushes, q-tips, Scotchbrite and Berryman's B-12 Chemtool for carb cleaning. Mild soap or diluted Simple Green for the diaphragms and then wipe with Armor-All.
    Don't submerge them unless you're tearing them down completely; whatever you submerge them in can get trapped in the throttle shaft seals.
