urgent tank advice needed
Discussion in 'XJ Technical Chat' started by jctxrt, Apr 26, 2014.
  1. jctxrt
    jctxrt Member
    Hi. Can someone please tell me if a xj550 maxim tank is identical to a 650 maxim tank. My 650 maxim tank is no good internally and I have found a 550 for sale online. Cheers
  2. hogfiddles
    NO, they are NOT the same.
    The 750 maxim tank is a direct bolt-on, though, and gives you more fuel capacity, too..
  3. jctxrt
    jctxrt Member
    So the mounting for the 750 is identical to the 650 ??.
    Is it physically a much bigger tank than the 650. ? Is it the same shape?
    Cheers
  4. skippy344
    skippy344 Member
    Aggieland, TX
    Hi JC,
    I don't know what your skill level is, but there is a product called POR15, that is used to clean, prep and coat the inside of gas tanks, that will return you tank to new. Google it, as I don't want to advertise on this forum. The maker will sell you the kits directly.
    But do the inside, BEFORE you finish the outside. You will be messing with some righteous chemicals!!
    Once the inside is done, find out how much you will be charged to get the outside powder-coated. Makes for a really tough finish against gas, and looks really good too!
  5. XjNJ82
    XjNJ82 Member
    New jersey
    I've just discovered the same problem on my bike! there are some pretty good rust patches on the inside, the fuel that came out looked like mud mixed with peeled paint. Will POR15 save my tank?
  6. skippy344
    skippy344 Member
    Aggieland, TX
    Yes, I believe it will, if there are no holes rusted through! LOL
    If you do have holes, clean it out completely of all remnants of gas, and have a metal man fix it for you.
    Then POR that puppy!!
  7. jctxrt
    jctxrt Member
    My biggest issue is the current tank had a tank liner in it. That liquid liner stuff. Now it is all peeling and flaking off internally. Not sure if I can do anything about this. ?
  8. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I believe one of the POR products will take the lining out, but check their website to make sure.
  9. hogfiddles
    The 750 maxim tank has ALL mounting points IDENTICAL to the 650 maxim. It is a drop on and go upgrade. The tanks a gallon larger. It is slightly taller and wider. It give the bike nicer visual "line" too... If you want to see one, go to my gallery and take a peek at the full dress 650maxim-- that's a 750 maxim tank on it. Many people here have done that upgrade.
  10. skippy344
    skippy344 Member
    Aggieland, TX
    Yes, there is a kit, fro POR that will strip that KREEM liner, or any liner.
    I am about ready to do another tank for Rosie, or ebay!
  11. junkmn
    junkmn Member
    Colorado
    Acetone removes Kreem.
  12. skippy344
    skippy344 Member
    Aggieland, TX
    Nice! Junky!!! Good to know!
