Valve adjustment, carb sync
Discussion in 'Hangout Lounge' started by fakeplay, May 12, 2011.
  1. fakeplay
    fakeplay Member
    Newburyport, MA
    Hi, I was just woundering if it matters. Does it matter if I adjust the valve first and then sync the carbs ? or If I sync the carbs first and then adjust the valves. Thanks
  2. Saber
    Saber Member
    Reading, PA
    Yes, the order is important. First, you need to adjust the valves and then sync the carbs.
  3. JFStewart
    JFStewart Member
    Ontario Canada
    First is to adjust valves. If they are wrong, nothing can be adjusted correctly. Syncing carbs must have correct vacuum and with valves not correct=vacuum not correct.
  4. fakeplay
    fakeplay Member
    Newburyport, MA
    Valves 1st, carbs 2nd. Got it. Thanks
  5. Gearhead61
    Gearhead61 Member
    Hattiesburg, MS / Tyler, TX
    I don't mean to hijack because I think this question is appropriate... after adjusting valves, does it make sense to colortune before or after you sync the carbs? Or will it be a sync-colortune-sync-colortune (colortune-sync-colortune?) process until it's all good?
  6. bigfitz52
    Pretty much.
    ColorTune is for fine-tuning idle mixtures. Sync should be done first; then re-checked afterward. Chances are (unless the mixture adjustments were way off to begin with) that the mixture tuning won't affect sync much if at all.
