valve adjustment reveals loose not tight spots.
Discussion in 'XJ Technical Chat' started by wonderdawg, May 31, 2010.
  1. wonderdawg
    wonderdawg Member
    So. California
    I just had the valves adjust on my 1983 xj900 seca. It surprised me to learn that my valves were on the loose side of things instead the normal tight. So I have a couple of questions:
    1. I do not know what this means.
    2. What would cause them to be loose?
    3. Should I be concerned?
    4. What might the side effects be of havling loose valves? I did notice that my fuel economy had dropped by 4MPGs. I had been getting around 42MPG. Now I am getting only 37MPGs pre-adjustment.
    Any info. would be greatly appreciated.
    Regards,
    W. D.
  2. wizard
    loose is better than tight, without knowing the history of the bike it's a job to tell, could be that the PO did a poor job.
    How far out were they?
  3. wonderdawg
    wonderdawg Member
    So. California
    These are the numbers for the valves starting with the left hand side exhaust valves and then going accross to the right hand side. Then the shim size that was used to correct it. Followed by the new corrected measurement for exhaust and intake.
    Measured Exhuast:
    .23 .20 .20 .20
    Shim:
    275-280
    Corrected:
    .18 .20 .20 .20
    Measured Intake:
    .18 .15 .15 .18
    Shim:
    280-285 280-285
    Corrected:
    .13 .15 .15 .13
    Againtaanks for the info.
    Regards,
    W. D.
  4. Swissjon
    Swissjon Member
    Probably wear and tear.. It's perfectly normal for valve shims to need replacing as a part of the service interval, the ones you had were not really too far out. Correct spec is .11-.15 doe inlet and .16 to .20 for exhaust.. I would think that next time you get the bike serviced, the other 5 shims will need replacing.
    Really not something to worry about.
  5. wonderdawg
    wonderdawg Member
    So. California
    :eek:
    Cool I was mostly concerned because my fuel economy had fallin off so much. I am hope that have adjusted the valves will bring my MPG back up.
    Thanks,
    W. D.
  6. Swissjon
    Swissjon Member
    Maybe your fuel economy has more to do with your right hand! :)
    If it's getting bad, maybe there's another fault, but your valves are spot on..
  7. wonderdawg
    wonderdawg Member
    So. California
    8)
    Cool I while have a talk with it. Could be your are absolutely correct. But I will have to keep an eye on it now that the adjustment has been done. Thanks again.
    Regards,
    W. D.
