valve cover bolt holes stripped... options?
Discussion in 'XJ Technical Chat' started by mrredbaron, Apr 30, 2015.
  1. mrredbaron
    mrredbaron Member
    Brighton, MI
    Right side, front two outer valve cover bolt holes are stripped. I have no idea what to do because the valve cover bolts are so unique.. Right now I'm considering adding some sort of c-clamp to stop a valve cover leak. I have no experience as a machinist so any ideas are welcome.
    Help!
    While the bolts themselves are somewhat unique, the threads are a standard metric thread. A shop can put inserts in the stripped holes. If you want to do it yourself it's not terribly difficult, but you should buy extra inserts and practice putting them into a peace of scrap before fixing your head. I'm currently on a break at work, but can post more information on the process later.
  3. chacal
    What year/model bike are you working on?
  4. mrredbaron
    mrredbaron Member
    Brighton, MI
    82 550 maxim. I'll call shops tomorrow for a quote.
  5. mrredbaron
    mrredbaron Member
    Brighton, MI
    Looks right
  6. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Got a 1/4in drill bit? An adjustable wrench? All you need is a Helicoil kit. You drill out what is left of the threads in the (relatively) soft aluminum, tap some new threads for the insert, and place the insert into thenew hole. Done. I did all 8 of my outer bolts last year cuz 3 were leaking, so the others were only a matter of time. Only took 20 mins for the whole shebang. Kit cost $40 and can be found at most auto shops, though I keep finding them for cheaper at tool shops. They come with (I think) 12 inserts, so you can even have leftovers. Which is fortunate, since it's a very common size on our bikes. Had to Helicoil my chain tensioner. Works like a charm.
    The thread size you need is M6 P1.0
  7. PilotSmack
    Calgary, Canada
    Just remember to put some painters tape across the oil galleries. Wouldn't wanna get chunks of aluminum floating in places you don't want floaties.
  8. k-moe
    The tricky bit (and the reason why I recommend practicing first) is drilling the hole dead straight. Because of the nature of how the valve cover bolts seat (the wide lower shoulder of the bolt seats flat on the cylinder head), the insert cannot be askew, or you risk cracking the head when the bolts are tightened.
    It is a very easy DYI job, but practice drilling a straight hole with a handheld drill and putting an insert or two into some scrap aluminum, or hardwood.
  9. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Drilling the hole straight is the key. Also don't drill to far down. Drill slow also a lube would probably help. I just did 3 threads on my 550. Took like 20 mins. Got it all back together and leaks are gone. M6 x 1.0 metric is what I used with a 1/4 drill bit. Good luck.
  10. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    helicoil is the way to go...
  11. mrredbaron
    mrredbaron Member
    Brighton, MI
    Okay. Just bought the helicoil M6 x 1 kit from amazon for ~$26. Took a bolt into auto zone and confirmed its a M6x1 so should be good there. With prime shipping it arrives Thursday.
    Any tips for drilling straight? I know my way around a hand drill well enough, but I mean should I prop the bike so I can come at it straight down and use the bubble level on the drill? How freaked out should I be by "drill it straight." I'm gonna be pretty darn careful.
  12. Polock
    the drill is going to want to follow the hole that's already there, but another set of eyes always helps. The other set of eyes can run a vacuum too.
    tapping always goes better with a tap wrench too. If you use something with one handle it's harder to keep the tap straight. WD-40 for tap lube, two turns in, then out, clean the tap and back in.
    you'll be fine.
  13. k-moe
    If you have a variable speed drill just go slow. If you have a single speed drill you will need to be a little careful at the beginning of each hole. In either case drilling the hole out in stages will get you a straight hole with less chance of getting crossways. Don't worry if you don't have a bit that falls between the size of the current hole, and the final hole for the insert. It's perfectly fine to drill in a single stage.
  14. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I have been having this exact issue
    ordered a kit
    will the bolts I have work in the newly tapped holes then?
    I can't imagine finding another bolt to fasten the valve cover with
  15. PilotSmack
    Calgary, Canada
    Yes, that's the point. The bolts are an M6 P1.0 thread. So are the holes in the head. The threads in the head are pooched cuz they are aluminum. The bolts are steel (I think, someone correct me if I'm wrong), and they outlast the aluminum threads in the head. All you are doing is removing the old threads in the head, and placing a new set of steel threads that are M6 P1.0 in the head.
    Hotcakesman likes this.
  16. Hotcakesman
    South Dakota
    awesome!
    so sick of weeping issues with my bike
    I had a bent valve cover and I have torn up the holes
    can't wait to have my bike back on the road
  17. PilotSmack
    Calgary, Canada
    The weeping could also be an old rubber gasket and donuts. Food for thought. (Pun intended)
  18. Hotcakesman
    South Dakota
    nope and nope
    bent valve cover messed everything up
    I have broken 3 camshaft mounts
    and the last one that broke I can't find all the broken parts
    I got most of the aluminum chunks
    but one small one remains
    I am hoping it is in the oil filter
    but the bolt is stripped
    so I am going to be cutting it in the next few days
    what a nightmare
  19. k-moe
    The threads are pooched because someone over torqued the fasteners. Threads don't just go away by themselves. Either exceeding torque specifications, corrosion, or using a fastener that has a high galvanic index when next to the other metal is what causes thread damage. One really good method for dealing with the first one is to have a service manual and a torque wrench. The second issue is dealt with by using a thread locking compound, or anti-seize(depending on the application). The third requires a bit of thought and research. For example stainless steel and aluminum have a high galvanic index when in contact with one another, and will eventually become corroded into a single, nearly irremovable piece.
  20. Hotcakesman
    South Dakota
    I will admit to over torquing
    mostly due to the bent valve cover
    will helicoil
    still searching for small shard of aluminum
    hope to find it tomorrow
    do not I have a new valve cover and Len is shipping replacement mount
    will tackle Friday
  21. k-moe
    I guarantee you are not the first owner of that bike to over tighten fasteners. I have put far too many helicoils in far too many machines to believe that it was just you, or just the warped valve cover.
  22. Hotcakesman
    South Dakota
    and I do know the PO actually did do some maintenance
    so I am sure I was not the 1st to mess with it
    smart thing is I am actually fixing it properly
  23. mrredbaron
    mrredbaron Member
    Brighton, MI
    Alright guys, checking in. Helicoil went according to plan, thanks for all the insight. I was nervous but I think everything turned out okay. So thanks again.
    Bolted the valve cover back in place (7.2 ft/lbs) and those two gasket semicircles on the right side weep oil! What do I even do about that? Gasket, donuts, everything is brand new. Can I thicken it up with a little rtv?
  24. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Eh, just JB Weld the thing shut! Done deal!
    KIDDING!
    Did you RTV the top (valve cover) side of the rubber gasket? Is the gasket new? Are the donuts new?
    Check out Fitz's how-to on doing a valve adjustments. Follow his final steps for the part about putting the cover back on and you shouldn't have any leaks at all. I did, and I don't.
    EDIT: Oops, I see now that you said the gaskets are new.
  25. Xjrider92117
    San Jose Ca
    Maybe I got lucky? I just did the same thing your doing and I used zero rtv. I put just a bit of silicon grease on both sides. No leaks at all. Imo rtv just makes a mess. Although I've used every other time I've done the valves.
  26. k-moe
    Pull the cover, clean the semi-circle in the head, clean the semi-circle portion of the gasket, smear a thin layer of oil resistant RTV or Loctite 515 on the gasket. Problem solved.
  27. Hotcakesman
    South Dakota
    I really don't get the design of the 2 half moons
    why can't that just be a flat area?
    I am sure the engineers had a plan
    but I can't figure this one out
  28. chacal
    Those half-circle cutouts in the cylinder head (that the half-circles on the gasket seal into) are on the right side of the head, one for each camshaft. It’s where the boring machine came into the side of the head to mill the cam bearing journals, and since those journals are lower in the head than the side walls of the head, they had to drill away a small portion of the head sidewall to allow the boring bar to machine the journals. Those half-circles now have to be sealed up…………………
    BaldWonder likes this.
  29. Hotcakesman
    South Dakota
    makes sense
    just wish there was an insert and a flat gasket
    I know it is wishful thinking thou
  30. mrredbaron
    mrredbaron Member
    Brighton, MI
    Veeery interesting.. Touché Yamaha, touché.
    Checking in, permatex ultra black stopped the leak for the most part. Buttoning down the hatch I must have cross threaded one of the other bolts on the left side like a complete roob asshat, because it just keeps spinning. Will be helicoiling that one as well, when the cover comes off next time, because for now, it doesn't leak.
    Thanks for all the help everybody.
  31. hogfiddles
    There is..... But you have to have the non-YICS head for that---- lol
  32. chacal
    There is, it's called a non-YICS engine!
  33. hogfiddles
    Beat ya to it..... Lol
  34. chacal
    Dave, you are the Quick-Draw McGraw!
  35. hogfiddles
    Heehee....
  36. Hotcakesman
    South Dakota
    8 Helicoils later
    one broken bolt.. it snapped at the nub (I was only using finger strength) will drill out in the winter
    a new valve cover, new gasket
    3 Camshaft mounting brackets
    and a lot of time and frustration
    I am happy to say that my leaking is over
    it weeped so little I could care less.. I think it will settle and be all good
    I am happy to say I win!
    I was about to call it quits last week
  37. hogfiddles
    Glad you're set
  38. mstubbs726
    mstubbs726 New Member
    Boulder, CO
    Hey guys, I've over torqued a few of the bolts in my head as well, and broke a cam mounting bracket. Where can I find one of those?
  39. hogfiddles
    Do you mean one of the cam caps?
  40. fiveofakind
    San Diego, CA
    Stubs,
    Pics would help when asking questions sometimes.....
  41. mstubbs726
    Boulder, CO
    Ok so here's what I'm talking about: Is this a cam cap?
  42. k-moe
    That is not a cam cap. It's just there so the valve cover has something to bolt to in that area. You should be able to find a replacement on Ebay, or put up a wanted ad; someone here probably has one to sell.
  43. mstubbs726
    Boulder, CO
    OK, I can't find this little bracket individually but it looks like I can buy a whole cylinder head assembly for pretty cheap. Gotta love old jap motorcycles. Thanks for the help.
  44. hogfiddles
    I'll look around......might have one
  45. mstubbs726
    Boulder, CO
    I'd really appreciate it if you did Hogfiddles
  46. Polock
    do you have the rest of it?
    Rooster53 likes this.
  47. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    DOH!o_O
    Yeah you are going to want to make sure you have all the bits and pieces.
  48. mstubbs726
    Boulder, CO
    Oh I surely have little aluminum bits floating around in my engine now. Biggest piece I found was the size of a pea.
  49. k-moe
    Drop the oil pan and flush the engine.
  50. mstubbs726
    Boulder, CO
    That's a good idea, thanks for the advice. Oh boy, here I go fixin my mistakes again haha
    TheCrazyGnat likes this.
