Wanted Valve cover bolts
Discussion in 'For Sale, Trade/Swap, Wanted' started by Plumper, Jun 2, 2019.
  1. Plumper
    Plumper Member
    Taber
    Hey guys I need some valve cover bolts I got a 82 xj 750 maxim, I've been on this site tons but still learning where to post stuff and where so hope I'm in the right spot
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Check XJ4ever, link at top right. If he (Chacal) doesn't have them, probably no one does.
  3. Plumper
    Plumper Member
    Taber
    Thanx I did but I didn't find them on his list
    You're lucky it was the bolt that gave out. Usually when they are overtightened it's the casting that fails.
    Just snug them up. The shoulder contacts the head when it's tight.
    Chitwood likes this.
  5. Plumper
    Plumper Member
    Taber
    I'm glad the head didn't crack, I don't know what happened I had my wrench set to 7.2 they were all fine then that one just snapped, I was hoping it wouldn't leak but it seeps out a little bit at the bottom of the half moon at the front everywhere else didn't leak I'm worried if I snug em more I'll snap another one, maybe I'll just smear a little bit of that rtv goop at the bottom of that one moon, thanx dude
    Panzerclaus and k-moe like this.
  6. k-moe
    The half moons usually do need some sealant on them.
  7. Plumper
    Plumper Member
    Taber
    O ok well once I get my hands on some bolts I'll take it apart again and put some sealant in those spots, just kinda a kick in the balls ive been fighting with an idel problem for a bit and finally found it. It was my valve clearance all 8 were horrible like never been done in 37 years had to drop 2 shim sizes on most but it fixed the problem right up
  8. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    If you didnt replace the pressure washers on the bolts I'd highly recommend it
  9. Plumper
    Plumper Member
    Taber
    I will be doing that as soon as I track down replacement bolts but they seem to be hard to find, the donuts and washers are easy but I've only found 1 Yamaha site that have bolts $37 usd for 8 so but the time I pay canadian dollars that's a bit steep for 8 bolts, can I not just use regular bolts of the same length and size if I use the donuts and washers? What's the point of that flair end right by the threads
  10. Simmy
    K-moe answered that.
  11. Plumper
    Plumper Member
    Taber
    Ahh yes i see that now
  12. k-moe
    The special shouldered bolts also retain the rubber donuts, and prevent them from being damaged by the fastener. Using a regular bolt is asking for trouble.
    Look at parts lots on auction sites. You should come across a full set for cheap that way (along with other small parts that you may need later).
  13. Chitwood
    Maybe @Toomanybikes has some? He is in canada just over the border I believe
  14. dkavanagh
    Rochester, NY
  15. Plumper
    Plumper Member
    Taber
    Ok thanx,
  16. Plumper
    Plumper Member
    Taber
    Ok I'll look for his stuff
  17. Plumper
    Plumper Member
    Taber
  18. Toomanybikes
    Tsawwassen bc
    Hi @Plumper
    I’m just outside Vancouver.
    I have tons of them for your 750.
    Biggest problem is people over tighten the bolt to stop a leak when they need to replace the rubber doughnut on the bolts.
    And when doughnuts are shot it doesn’t put enough pressure on the valve cover itself so the main vc gasket also leaks.
    Chitwood and k-moe like this.
  19. k-moe
    I am a bad moderator. We have polluted this thread long enough.
    Any further discussion about fixing bikes should go into the thread for the bike in question.
  20. Plumper
    Plumper Member
    Taber
    Sweet ok I'm just east of lethbridge so how do I get my hands on some of your bolts? I'm not even sure how that happened I was tightening them with my torque wrench after doing my shims and new gasket it was all going good then snap
  21. XJ550H
    do not use a torque wrench and back to your thread or start one
  22. k-moe
    Moved for clarity, and kindness.
