valve shim swap
Discussion in 'XJ Modifications' started by RiceBiker, Jul 29, 2014.
  1. RiceBiker
    RiceBiker Member
    San Leandro, CA
    Let's see if these make sense to anyone else.
    Valve specs.
    Gauged #1(E) .178, #2(E) .0762, #3(E) .203, #4(E) .178
    shims #1(E) (2.85), #2(E) (2.85), #3(E)(2.75), #4(E) (2.85)
    Gauged #1(I) .1016, #2(I) .127, #3(I) .203, #4(I) .0762
    shims #1(I) (2.80), #2(I) (2.75), #3(I) (2.80), #4(I) (2.90)
    swap 2E - 4I, 4I - 3I, 3I - 3E, 3E - 2E
    82 XJ650, Maxim
  2. quebecois59
    First let's list which valves are not in specs:
    E#2 too tight by two increments so you'll need a 275 shim
    E#3 is a bit loose but not by much I wouldn't touch it
    I#3 is too loose by one increment, you'll need a 285 shim
    I#4 is too tight by one increment, you'Ll need a 285 shim
    I think the only ones you can swap is E#2 to either I#3 or I#4, but you will have to buy one 285 and one 275.
    I could be easier to tell for sure if you'd measured with metric gauges, you wouldN,t have those confusing digits at the end of each reading. (for example 0.0203, the 3 at the end doesn't help at all).
  3. Polock
    i don't know what those measurements are in. what kind of gauge measures
    .0762 ?
  4. quebecois59
    Looks like the result of a conversion calculation
  5. RiceBiker
    RiceBiker Member
    San Leandro, CA
    After swapping some shims around here's what I get,
    E1) .16, E2) .20, E3) .16, E4) .18
    i1) .13, i2) .13, i3).08, i4).13
    i3 is a little tight, it's got a 285 in it now, going down to 280
    Bought a compression tester, but doesn't seem to be working right. The gauge doesn't hold the compression. Tried it on my car, same deal.
  6. bigfitz52
    Good job on the shims.
    Take the compression tester back and get one with an obvious "Schrader valve" (release valve) on the fitting just below the gauge head.
    It will probably run you a couple bux more than the one you got.
  7. RiceBiker
    RiceBiker Member
    San Leandro, CA
    Got one from Sears. Seems to work better, at least it's holding the pressure.
    #1) 130
    #2) 125
    #3) 128
    #4) 130
  8. hogfiddles
    That's high enough and even enough that it should run ok. Getting a little tired but still within rideable reason.
