Valve Shims and clearances
Discussion in 'XJ Technical Chat' started by Metmop, Sep 19, 2009.
  1. Metmop
    Metmop Member
    Orlando Florida
    OK I have a 1983 XJ750 maxim.
    I had a oil leak from the valve cover gasket so am replacing the gasket, while I am at it am checking the valve shims and are replacing if neccesary. Talked to lenny goin to order the YICS tool and doin a carb job next, but first I wanted to see if I have read this right. From what the hayes manual says the valve clearances are
    Inlet .11 to .15 mm
    Exhaust .16 to .20 mm
    At this time I have Inlet #1= .12, #2=.16, #3=.14, #4=.14
    Exhaust #1=.21, #2=.16, #3=.19, #4=.14
    So If I read this right I need to dismantle the bike and determine the shim, for #2 inlet decrease by .05, for #1 exhaust decrease by .05 and increase #4 by .05. Now I measered these with METRIC feeler guages and I guess what I am asking is if they only increase/decrease the shim by .05 is the .01 that I am off worth the time and trouble to do the extra work.
  2. chacal
    Yes, your analysis and size changes needed are correct.
    Yes, you want to pull out the currently-installed shims on the ones that need replacing and replace with the properly sized shims, espcially on that #4 exhaust. Tight exhuast valves are a disaster waiting to happen. And besides, any further tuning that you wish to do on the bike (synch, color-tuning) is basically a waste of effort and time if your valve clearances are not set properly!
  3. bigfitz52
    +1. Too tight is too tight, even by .01mm. Reason being, they tighten as they wear; if it's "just too tight" now it will be "really too tight" real soon and how often do you want to do this, anyway?
  4. SQLGuy
    SQLGuy Well-Known Member
    Not sure about your use of the words "increase" and "decrease".
    For example, on the #2 intake, which is a bit too loose, you want a .05 THICKER shim in order to fill in the gap, reducing it to .11. Conversely, for the #4 exhaust, you want a .05 thinner shim in order to increase the gap.
