Want Gas Cap Without Lock. Suggestions?
Discussion in 'XJ Technical Chat' started by dubyaohohdee, Sep 16, 2012.
  1. dubyaohohdee
    dubyaohohdee Member
    Prob USA
    I do not care about the lock or the factory look. Any suggestions on a compatible cap? Is there just some generic cap I can put on there? Sorry if this is a stupid simple problem. Please include links if you have suggestions. Thanks
  2. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Try a cork! or a bath tub plug! All seriousness aside, there are no generics out there. The gas cap was designed that way so if you crash you wouldn't tear your balls off as you slid up the tank. Just live with it.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    If you don't want to use a key just remove the tumblers from the lock so any thing will turn it
  4. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I don't think that is what he's looking for MN.
  5. MN-Maxims
    Saint Paul, MN
    Pretty tough to find any type of vented gas cap to fit a tank like what we have. If a guy were into fabricating you could cut the tank and graft a screw type cap and part of a older bikes tank onto a maxim tank. At the end of the day that's a lot of work.
  6. dubyaohohdee
    dubyaohohdee Member
    Prob USA
    Yeah, I dont really know what options are out there in general. I mainly just dont like having to use the key. Guess I will just have to deal with it.
  7. dubyaohohdee
    dubyaohohdee Member
    Prob USA
  8. MN-Maxims
    Saint Paul, MN
    I have one of those and it works just fine.
    MN
  9. Ted
    Ted Member
    Sioux Falls, SD
  10. k-moe
    The bar end weight seems like a good idea (and it looks good), but that means you are also leaving the ignition key on the bike. Most joyriders are dumb, but a smart thief will check to see what a weight is doing on a gas cap. Removing the tumblers and fitting a blank key (and suitable fancy handle) would do the job. But then...hey, free gas :D
