WANTED gauges for an 82 xj750 maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by ST0CKM0NK3Y, Sep 30, 2010.
  1. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Ok, so i just parted with my atari box gauges for my 82 xj750 maxim and was thinking about buying some smaller chrome ones from mikesxs but i happened to run across these and was wondering if they would wire into my harness (or plug in) The gauges i want from mikes will be close to $200 and i thought i might be able to save some cash with this route. anyone have these and know if this will work or have suggestions? thanks.
  2. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Ill post a pic in a second.
  3. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    [​IMG][/img] Like these ones, does anyone have these or know if the tach is electric or cable on these? also if they are even compatible with my xj750? thanks.
  4. Cmccully04
    Cmccully04 Member
    State College, PA
    I have set of these, that came with my XJ750, I replaced them for 1 small speedo
  5. Robert
    If they are off of an 82 650, you are good since they both use the electronic tach. If it is off of an 80-81, the tach is cable driven and you would need to do quite a bit of work to get them to work. There will be some odd connectors you won't need anymore, I'll work with you to identify them and jumper them where needed.
  6. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Do you want to part with them? PM me if so.
    Thanks man
    @robert: youll definitely be hearing from me for the wiring as i have no idea how this is going to work.. hahha
  7. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Still looking for these. Please PM if you have a set or know where i can get some.
