Warm up revs
Discussion in 'XJ Technical Chat' started by Beanz, Apr 18, 2009.
  1. Beanz
    Beanz Member
    Did a quick search about chokes and rpms but most people are asking what went wrong with their carb cleaning.
    I haven't touched anything on my bike (yet) but I was wondering what is a normal rpm range for letting your bike warm up with the choke on full? My bike jumps to about 3500 which seems pretty high so I usually back the choke off to about 2000-2500. This leaves the choke about 1/4 open.
    I'm not a mechanic so when I say "open" I just mean how far I have it cranked from the starting position. :roll:
  2. Polock
    2 to 2.5 is about right, 3 at full ain't bad either
    at full on mine sputters a little from too much fuel, so i back it off to around 1/2 maybe less
    hows it run after it's warm
  3. wizard
    I'd say you are doing the right thing, as the revs rise, back off the choke.
  4. Beanz
    Beanz Member
    Thanks.
    It runs very well. If I hop on it and open the throttle quickly it will hesitate but only the very first time. After that, flawless.
    Can I adjust the choke cable so that full open does rev it so high?
  5. bigfitz52
    Yep. In the middle of summer, my '81 needs only about 1/3 "choke" to start and warms up almost immediately.
    I usually keep easing the choke off to hold the motor around 2500-2Krpm if I bring it down too far when cold it stumbles. You've got it right.
