Weird Starting Problem
Discussion in 'XJ Technical Chat' started by Stokie, May 7, 2011.
  1. Stokie
    Stokie New Member
    Stoke-on-Trent, England
    I have an XJ550 and she spins up and starts no problem at all... usually. I have found that the trick is to use no throttle or choke (even when it's cold) and once she fires open the throttle quick, and then dial in a bit of choke with the thumb lever until she warms up a little.
    However, if she doesn't start on the first attempt, she won't start no matter how much you crank the motor. Leave her alone for 30 minutes and you can try again. It's almost like resetting the process. As she'll fire up fine, but if you don't catch her again on that first attempt it'll be another long wait.
    This is not good at the fuel pumps 8O
    Any ideas where I should start looking guys?
    Cheers....
    Stokie
  2. macros10
    macros10 Member
    Newport News, Virginia
    Have you tried putting the petcock on prime for 20-30 seconds before attempting to start?
  3. SQLGuy
    SQLGuy Well-Known Member
    Sounds like classic flooding to me. You're getting WAY too much fuel, and if you don't get enough air moving through the engine immediately, the plugs are getting wet and won't fire.
    If you flood it, the easiest way to start it without waiting too long is to disconnect the vacuum line from the petcock (to shut off fuel), then crank with wide open throttle. Of course, you'll then need to reconnect the vacuum line to keep it running...
    Probable causes are all the standard carb things: do they go clunk? Cleaning. Check for holes in diaphragms. Check pilot screw adjustments.
