Welding Exhaust
Discussion in 'XJ Technical Chat' started by corner27, Jun 15, 2008.
  1. corner27
    corner27 Member
    Manitoba, Canada
    The mufflers on my bike are coming loose. I tried tightening the clamp, but it won't tighten it enough. Is there any problem with just welding them together? It's the join where the muffler connects to the 4-2 part.
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Your probably missing the Exhaust Gasket and it won't tighten up to stop the leakage. That would be #5.
  3. corner27
    corner27 Member
    Manitoba, Canada
    It's where number 2 connects up. The one side has no gasket, and it tightens right up, so I'm not sure. Will welding it work?
  4. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    I wouldn't do it. If you off just a little you'll never get a good seal at the head.
    You have to take it off to do either. I'd just spring for new gaskets, after you get them off, you'll know how many.
  5. 85MaximXX
    85MaximXX Member
    S.W. michigan
    i got the same thing the right side is loose RP you are looking at the forward side the problem exists on the rear side of the collector I put some galvanized strapping between the pipe and clamp and it worked for a bit. THere is no gasket for this in the pic above and I seen no reminents either. Muffler cement would also work as it can be removed if needed. slather it up and assemble let dry per iinstructions and you should be fine.
  6. corner27
    corner27 Member
    Manitoba, Canada
    I tried that gasket in a tube stuff, but it doesnt seem to want to hold. I was also thinking that if I put some metal inbetween it will be able to tighten it with the clamp
  7. RickCoMatic
    Take a section of Copper Tubing with a larger Outside Diameter than what needs the gasket.
    Cut a "Slanted" section out of the tubing fit it in the space to be sealed.
    If you get the cut right ... the tubing will act as a gasket and give you some purchase to make a clamp work.
