well today i got my very own crankcase full of gas...
Discussion in 'XJ Technical Chat' started by joshs700n, May 31, 2014.
  1. joshs700n
    joshs700n Member
    mass
    I filled the tank and left the petcoc on prime all night this morning I had my very own crankcase full of gas xj700n
  2. bendoza
    bendoza Member
    portland, or
    its like winning a scratch off.
  3. midnightmoose
    midnightmoose Member
    York, PA
    I see some carb work in your immediate future!
  4. joshs700n
    joshs700n Member
    mass
    Yeah my float seals are hard and old rubber
  5. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    go with the brass float seats and needles. Chacal has them. Work great in my bike and no rubber to go bad.
  6. joshs700n
    joshs700n Member
    mass
    Sounds good this is probly over the 10th time I've had to pull the carbs
  7. bigfitz52
    Leaving the petcock on PRI is a test. Your float valves failed.
    You know they've passed when you can accidentally leave it on PRI for A WEEK and nothing bad happens. (It's a good feeling, too.)
    Now you get to learn yet another skill.
  8. joshs700n
    joshs700n Member
    mass
    Yes its a very good feeling
  9. joshs700n
    joshs700n Member
    mass
    I put 20w50 valvoline regular motorcycle oil in it and I haven't heard the starter grinding sound yett but I'm not gonna speak too soon
  10. joshs700n
    joshs700n Member
    mass
    How does the gas get to the crankcase from the carbs (I know my float seals failed) what path does it follow
  11. hogfiddles
    Leaky petcock, leaky float needle, bowls fill, overflow into cyl chamber, leaks down past rings, fills crank case.....
  12. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Right. When the bowls fill too much, fuel percolates up out of the floor of the carb through the small gap between the main jet and the jet needle. And from there it runs into the cylinders.
