went in for engine work
Discussion in 'XJ Modifications' started by SUPERMAN8599, Jan 28, 2015.
  1. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    hey there guys its been a while since I don't post anything. I had been having issues with my bike since I got it 1982 xj750 and with the help of you guys I was able to find @razz1969. he has been my go to xj guru here in Houston. I took the bike to him for some engine work and with his vision I was convinced that @razz1969 had some great ideas and we are going for them... we are doing customization on that bike I cant wait to see the final product!!! he really has a great understanding on these bike and me being a youngster (25) I have learned a lot from him I just want to give kudos to him and all other people on here that are always happy to lend a hand. we got new clip on handle bars, new speed-o getting rid of the Atari box finally!! new clutch and brake levers a different paint job... I was worried more about looks than mechanical and @razz1969 kept me in check with fixing the mechanical first forks and seals valve shims spark plug boots... its been a long process and @razz1969 has been great I recommend him to anyone around our area... Message_1418227926519.jpg Message_1418964922959.jpg Message_1419973684726.jpg Message_1420227085780.jpg 20140923_080632.jpg 20140923_080632.jpg
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    I am guessing these are all before pics? what are the deets on that clock?
    FU
  3. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    yes those are before pics... that how I had it the only mod I did was the clubman bars.. deets? @cyclenoob what do you mean by that?
  4. Polock
    yikes, get those keys off the tank
  5. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    @Polock haha yea I should have thought about that when @razz1969 does the new paint I will definitely be careful thanks for the heads up
  6. FtUp
    pacific northwest
    details.
    FU
  7. FtUp
    pacific northwest
    it's not a good idea to have all that weight hanging on the ignition either. over time the ign key and cylinder will wear out prematurely. I only use the ign key in all of my vehicles. the rest go in my pocket.
    FU
  8. razz1969
    razz1969 Active Member
    Cleveland, Tx
    Man... talk about blown away. Thanks superman. I do it for the love of the bike, not for the love of money. So any how here is a little teaser. Keep in mind I am not finished with the tank, got to do a couple more coats. I am all most at the point of putting parts back on instead of off. 20150128_222218.jpg
    kwes likes this.
  9. ThinkingTime
    ThinkingTime Member
    Canada
    FtUp likes this.
  10. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Lookin good! Interesting to me that your stock tank has the indented badge mounts where the yamaha emblem screws in. My Yamaha badges simply stuck on.
    Also, could you post a link/details to your brake/clutch levers? I can't seem to find any like that with a 16mm piston.
    Thanks!
  11. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    @ThinkingTime yea it is the same cfmoto Cluster we found on ebay.... @cyclenoob yea i think i will change That habit too thanks for that heads up... @BrosefStalin i can find the link where @razz1969 found them at http://m.banggood.com/New-Black-Uni...ke-Clutch-Lever-Master-Cylinder-p-934809.html now these are coming from a land far far away i believe it took about a month for @razz1969 to get them...
    Oh man @razz1969 you were holding out on these pictures haha man once its on the bike its going to look better!!
    @razz1969 has been sending me bits and pieces of his work this is the first time i see the whole lot of parts together he has just been teasing with the other pics haha
  12. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Thanks for the link. That's ok, there's still time before I can ride. I just need to know if they'll actually work with these brakes. I don't want them to be too firm or loose which is why I want to stay with a stock piston diameter size. Hopefully @razz1969 can chime in. Unfortunately none of those Asian sellers ever advertise the actual piston diameter (The Xj750 dual disk is a 16mm) and so I never know what I'm buying.
    SUPERMAN8599 likes this.
  13. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Where in Houston are you two located? I am way up in the NW corner.
  14. Bigshankhank
    Bastrop, TX
    Oh yes, and what is the final color going to be? Looks to be a rough base coat, what are you using to smooth it prior to final coat?
  15. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    @Bigshankhank i live by Ikea @razz1969 lives about an hour from here for the paint we are doing a tough vht heat resistant paint this might be a bike from someone on here this is what we are trying to go for null_zpsaf4c6459.jpg
  16. razz1969
    Cleveland, Tx
  17. razz1969
    Cleveland, Tx
    I don't think this is a Maxim tank, its to narrow.
  18. razz1969
    Cleveland, Tx
    I am in Cleveland, Tx. Maybe the three of us can get together, have a bbq and go for a ride around Lake Livingston.
  19. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    Yea!! That sounds like a plan to me any excuse to ride!!
  20. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Thanks for the link sir. Let me know how they work out with the dual disk setup, I'm thinking very hard about ordering them.
  21. Bigshankhank
    Bastrop, TX
    Still gotta fettle my carbs, maybe sometime this spring I'll have it back together. Thinking about ordering some parts this weekend to give me something to do since the weather is turning shitty next week.
  22. razz1969
    Cleveland, Tx
    if you need some help wit the carbs let me know, i have every thing you need including a carb stand and free advice.
  23. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I might be able to help with the carbs as well. We just moved into the "Golden Triangle" area a couple months ago.
  24. razz1969
    Cleveland, Tx
    Man your only 65 miles frome down 105. We have enough xj riders now to start an south east texas chapter. There use to be a realy good mc wrecking yard in beaumount to give a heads up.
  25. Bigshankhank
    Bastrop, TX
    There are a couple bike salvage yards on the East side of H-town, one has a few XJ's but needless to say they are in rough shape.
    I have a carb rack, all the tools and all the know-how to tune them, I just don't have the time. And after carbs, the bike needs tires, brakes, and I need to clean & seal the tank. I am not going to work about paint right now. It'll happen, I just need the time off of work to do it.
  26. razz1969
    Cleveland, Tx
    +++1 on the time thing. Full time job, father, husband, home handy man, on and on... hard to get some mc time.
  27. k-moe
    There are two tanks for the Maxim. The tank for the 750 is larger (wider) than for the 650. It looks to me like he has a 650 Maxim tank, which does use bolted on emblems.
  28. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    Im cool with that chapter idea how do we get it going that be exciting!!
  29. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    oh man I wish I had the 750 tank how much do y'all think a salvaged one costs
    what are some ideas for patches does this website have jacket patches for xj riders?
  30. Bigshankhank
    Bastrop, TX
    Just find the logo of an existing MC club that you like the look of, and use that but with your own rocker panel beneath it. Easy and quick, nothing to worry about. If you want to spend the money, get it really big and wear it on your back.
  31. wink1018
    Muncy, Pennsylvania
    The 750 Maxim tank is about 5 gallons. The 650 Maxim tank is roughly 3.6 gallons. I am running a 750 tank on my 650. Before the pods, I was able to get 220-ish miles per tank.
  32. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    ok guys so @razz1969 just sent me his idea and I want your thoughts 3...2....1....GO!!! Message_1422745936619.jpg Message_1422746130265.jpg Message_1422746156076.jpg Message_1422746236142.jpg Message_1422746694816.jpg
  33. k-moe
    Watch tthe driveshaft angle. The U-Joint can only go so-far and remain intact under load.
  34. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    oh ok I see maybe @razz1969 can chime in and tell us his vision on this...
  35. razz1969
    Cleveland, Tx
    I am not modifying the rear suspension. Just haven't atached the shocks yet. We are talking about the tank and seat combo, although this is a very rough mock up.
  36. hogfiddles
    Looks ridiculous
  37. razz1969
    Cleveland, Tx
    I agree in its currant state. The grab bar will go and the side panel would be changed to make it flow. Along with the new clip ons, controls, and speedo i think its what we are looking for, the street fighter look. Remember this is just a ruff placing the parts in the approximately place trying to get a vision mock up. Now I wouldn't do this to a factory correct bike. To begin with this bike didn't have the factory tank, handle bars, side cover, and the gauge clusters had some serious faults. Therefore this bike is a great candidate for this kind of modification. Superman posted this to see if any one can see where we can go with this and try to get some positive response or constructive criticism that this site is famous for.
  38. SUPERMAN8599
    SUPERMAN8599 Member
    Houston Texas
    Like @razz1969 said its a rough mock up... and @razz1969 is right my bike was rough nothing really original about it like tank, bars, etc... and i know if my bike had more original parts on it @razz1969 probably would not help me do any mods and would have rather conserve the originality of the xj and i would follow his know best advice but since it wasnt in any way original we want your thoughts on how we can accomplish this
  39. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Looks to me like the bars are going to hit the tank no matter how it gets fitted. If that's not the case, it could be cool.
  40. razz1969
    Cleveland, Tx
    I am putting clip ons so I can adjust the bars to where they wont hit.
  41. wink1018
    Muncy, Pennsylvania
    Use a BFH to make the clearance.
