Wet setting carbs, having problems... :(
Discussion in 'XJ Technical Chat' started by kudoskun, Jun 29, 2013.
  1. kudoskun
    kudoskun Member
    Minneapolis MN
    By all accounts, the tang level I have set is the same across all floats.
    Test 1 - ensured the carbs were level based off a spirit level across all 4 carb hats, and level straight on from carb 4.
    Carb 1: 1cm low
    Carb 2: Perfect
    Carb 3: 2cm low
    Carb 4: Almost no fuel - literally a drop.
    I drained the carbs, flipped the rack over and checked the tangs (made no adjustments). To check the fuel rails and flow - I shot compressed air through the fuel line - and all of the floats started to, well...float on air.
    When the floats were off, and being rechecked - I checked all the needles, and they were all springy and working. Everything but the floats are new from Chacal.
    I got everything buttoned back up, and ready to retest. Again, carb 4 did the same no fuel bit. I tilted the rack side to side, I was even able to shoot compressed air back through the carb and see air flowing up the fuel line! But no fuel would flow into the carb.
    When I rebuilt them a few weeks ago, I got new seals, and made sure to spread silicone grease on the o-ring fittings too.
    With all of that said, my 2 issues are these -- why isn't carb 4 getting fuel; and why would the fuel levels all be different if the floats are set identical?
    Thoughts, comments, exorcisms welcome...
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    spring tension of the needle valve might have something to do with the fuel levels not being even across the board.
  3. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    stuck needle in #4 causing no fuel in bowl maybe........
  4. kudoskun
    kudoskun Member
    Minneapolis MN
    All new. For the sake of testing if they're stuck -- I took out the floats, and shot compressed air through the fuel line -- and all the needles shot out of the seats onto the table.
    New idea -- pyrex carbs. So we can see everything inside of them!
  5. fiveofakind
    San Diego, CA
    did you buy aftermarket float needles......which are about 1mm longer than the OEM needles....float adjustment is necessary for which you did......something is causing no fuel in Carb #4.....if carbs are on bike.....take the float bowl off if you can......& turn the petcock to prime.....to see if fuel is flowing to #4......
  6. kudoskun
    kudoskun Member
    Minneapolis MN
    Even if the needles were different heights -- they'd still be open if no fuel was in the bowl.
    You mention a good idea - and I'll try it - removing the float and needle.
    With the carbs off the bike, I've only been setting it to prime too.
  7. k-moe
    Get a pyrex measuring cup. Use it instead of the float bowl on #4. See what happens. The needle may be sticking. The float may be getting hung up on something and not be able to drop enough to lower the needle. There may be a bit of "crap" stuck in the fuel inlet passage of #4 that can be blown back toward the tank, but not find it's way past the needle seat, which would block fuel flow (acting like a check valve).
  8. kudoskun
    kudoskun Member
    Minneapolis MN
    Well, I managed to get it working the next day. Chalk it up to voodoo.
    I pulled off #4 carb from the rack, checked all of the passageways, and fuel seat. Proceeded to put it all back together and on the subsequent test - #4 filled the bowl!
    I'm still having problems getting the float levels just right, but I suppose once they're done now, they'll be good for another 30 years.
  9. lanker
    lanker Member
    Cicero, NY
    Wet setting fuel levels in on my top 10 list of things I hate to do the most... it's a 12-pack job... 1 nano-millimeter of tang adjustment equals about 2mm of fuel level change.
  10. kudoskun
    kudoskun Member
    Minneapolis MN
    So, carbs are rebuilt and wet set - put back into the bike, but now it only starts with starting fluid.
    Battery is charged, I've tried choke on and off, and even kept the throttle at WOT and it wont stay running.
    After initially rebuilding the carbs, I set the mix screws to 1.5 turns, but proceeded to change it to 3 full turns from the bottom.
    Regarding the carbs, the enrichment circuits were cleaned, zestfully (!), the bowl jet was cleaned up, and everything was poured over to be as clean as possible.
    I'm at a bit of a loss now. Hopefully more searching the forums will reveal something...
  11. lanker
    lanker Member
    Cicero, NY
    Just to be 100% sure...
    In your initial post you indicate the fuel levels were low by cm (centimeters)... you did mean mm (millimeters).. yeah?
  12. kudoskun
    kudoskun Member
    Minneapolis MN
    Nope, I meant centimeters. It's possible the carbs weren't entirely level, but the big difference was when I was playing with the tang on one of the carbs - not realizing... I think someone put it best -- nanometers equate to a few mm. So I bent it back inline with the other floats, and then proceeded to fine tune it.
    Present issues is that the bike wont start without starter spray. Everything is much cleaner than it was -- so I'd imagine it should fire right up, but alas it shares its fate with poor Yorrick, for now.
  13. kudoskun
    kudoskun Member
    Minneapolis MN
    I should add before I get reprimanded by Fitz, HogFiddles, or Rick -- the valve clearances have been checked and brought into spec about 50 miles ago (last fall).
  14. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Did you:
    A. Bench sync the butterflies? If so, what did you use for a gauge?
    B. Try adjusting the idle knob?
    Also, when is the last time you changed the plugs? And what do they look like?
    WOT doesn't enrichen the mixture like the enrichment circuit does because you are letting in more air along with the fuel, it just floods the carbs.
    And, is she breathing ok? (i.e., clean air filter)
  15. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    when i replaced my needles + seats, i had to bend the tangs way down and kinda start over. believe it or not, the 1 mm makes a huge difference in your carb set up
  16. kleraudio
    kleraudio Member
    Erie, CO
    Did you ever get the bike to start up?
  17. zenbruce
    zenbruce New Member
    Clearfield, UT
    My bike was running lean so I adjusted the floats so the fuel level is 2mm deeper and now it won't idle or start without starting fluid. Wow, these carbs are sensitive ! I'll set the floats back where they were.
  18. bigfitz52
    How about setting them TO SPEC: http://www.xj4ever.com/setting%20fuel%20levels.pdf Then they'll work properly, as long as the seats are clean and the float needles in good shape.
    Read the 'pdf' carefully; you are adjusting Mikuni BS28's. (A lot of the illustrations are Hitachis.)
    Float levels in the Mikunis are very important and will greatly affect how the bike runs. The spec (2mm below mixing body edge) only has a +/- 1 mm tolerance; these carbs reward precision.
    Here's an exploded Mikuni for reference: http://xjbikes.com/Forums/viewtopic/t=31061.html
    You didn't answer my valve shim question in your other thread.
  19. jmilliken
    Dillsburg, PA
    literally, when doing wet-setting, if you can see that you moved the tang, you moved it too much. bending the tang about 5 mm or so will take the bowl from empty to flooding.
    As was stated before, it's a 12 pack job. and time and patience. but you gotta do it, and gotta do it right....
  20. bigfitz52
    You do. Which is why it's more of a "Sunday morning with a cup of coffee and a clear mind" job; and save the 12-pack until after. Kinda like doing valve clearances.
  21. jmilliken
    Dillsburg, PA
    and this is why Fitz's bike looks and runs so much better than mine....
  22. kleraudio
    kleraudio Member
    Erie, CO
    LMAO!!
  23. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    It's more like a WHOLE pot of coffee. Took me 4 hours to do the carbs on the Radian. I must have got lucky on my Maxim. Only about an hour.
  24. jmilliken
    Dillsburg, PA
    yea... you must have gotten lucky... one time I spent about 2 days....
  25. bmarzka
    I'm not so lucky after all. Started the Radian yesterday and as soon as I put it in gear it stalled and wouldn't re-fire. When it was on the side stand I noticed the oil was half way up the sight glass (this can't be good). Pulled the filler cap, smells like gas. Time to pull the carbs again and see what I screwed up. And change the oil and filter.
  26. bigfitz52
    XJ OWNERS STARTING RITUAL:
    Before starting the bike, put it on the sidestand.
    Look at the sight glass. Should look empty.
    Reach up, grab brake lever and RH bar and stand bike up toward vertical, watching oil rise in sight glass.
    Stop before you tip bike over on self.
    Put bike on centerstand and re-check oil level before firing it up.
    Just get in the habit of doing this every time you pull the bike out, even if you rode it yesterday, and you won't get caught by surprise.
  27. bigfitz52
    Had another thought, this isn't mentioned in the how-tos as far as I know and it helps:
    When wet-setting floats, don't go by the first reading of any fill. When you're checking a float level, after you fill the rack, open drain, empty, and re-fill the carb you're testing two or three times before taking a reading of it. In other words, "cycle" the float valve; make it shut off, open, shut off, open, shut off before you read where it's shutting off. After adjusting, do the same thing. Do it when simply "wet-verifying" as well.
    I think sometimes it takes getting pressed against the seat a few times for the needle to "settle in" to where it wants to sit. Regardless of the theory behind it, the first reading isn't necessarily all that accurate.
  28. Bargomer
    Bargomer Member
    Southern California
    I was wondering if the pyrex measuring cup has to be molded to the carb body to create a vacuum or whatever. Or can I just have it under the carb and see how the fuel is going inside?
  29. FtUp
    FtUp Well-Known Member
    pacific northwest
    no, it just has to be held up against the bottom of the carb body.
    CN
  30. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    One more thing that I have heard it has happened before, are your cables hooked right? choke and throttle are going to the right place?
  31. schmuckaholic
    California
    Actually, they're all Hitachis in that writeup. I kindasorta did the Mikunis on the X in another file, but it works the same way for both.
